how to compare 2 drawings in creo?
.dwg files
.dwg is AutoCAD format ...
You can compare active Creo .drw file with picture of another Creo drawing using Compare Sheet to Picture located on Review tab (in Drawing mode).
Martin Hanak
Martin Hanak
is t possible to two tiff images in creo,
But i cant able to view the changes, could you please brief about how exactly it to be done.
Changes are displayed as a picture of differences.
For example:
I set the following config.pro options:
SAVE_DRAWING_PICTURE_FILE BOTH
SAVE_OBJECTS ALL
I opened drawing and saved it, Creo saved .drw and .pic files.
I moved dimension.
I applied Compare Sheet to Picture command.
The result is displayed temporarily. It disappears when you refresh the display. To put it into Clipboard, you can press PrintScreen button on the keyboard.
Martin Hanak
Thank you!
