Hi everyone,
I’m currently using a floating student license provided by my university, and I have a question about compatibility between the educational and commercial versions of PTC software.
As part of my project, I need to design a part and an assembly that will be inserted into an existing assembly created using a commercial license. The part should remain editable even after the project is completed.
Does anyone know if a part created in the educational version can be opened and modified in the commercial version without issues? Are there any restrictions or workarounds I should be aware of?
Thanks in advance for any insights!
Sincerely
Peter
Student and commercial versions are totally INCOMPATIBLE. Files created by one cannot be opened by the other.
The files are not compatible.
However, you (or your university) can contact PTC and they can help. There is a specific license that will convert the files. I assume this is NOT free.
If you are planning on doing this, you should definitely make arrangements with PTC prior to doing the work.
