Compiled Measures Data at Each Time Step
ptc-2580609
Hello All,
I am trying to find an easy way to export measures for each time step in a non-linear analysis. For instance, I have 5 time steps, and I want the measures for each time step, so they can be compiled. I have found that the "analysis_name".res file will have the first and last time step, but it doesn't have anything for the other steps? I am working in Creo2.
Am I missing something?
ehaenen
(To:Tmetcalf)
Hi Toby
The essence was that at some stage Beau's analysis had ceased to be a non-linear one, because he had added a shell representation to the model.
Only solid elements can be used for non-linear analysis.
The analysis then reverted to producing only measure results for begin and end of the analysis. As soon as the shells were deleted, we could select large deformation and the measures in each time step were obtained.
(Just like Beau said in his answer)
Regards
Erik
16 REPLIES 16
If this is a motion analysis, you can do a measure over time and output this to a graph, which can be output to a delimited text file.
Thanks for the reply, but its not a motion analysis. I am trying to get average slippage factors for contact regions for the increasing loads at each time step.
I would typically run the analysis, go to results, and then create a graph displaying a measure vs. time. Then click "File-export-excel".
/Mats L/
Mats,
Thanks for the respsonse. This way will work, but if I have 40 contact areas and 6 load cases, it will take a while to compile the results. So I was hoping there would be a file (.res) that would have all of them in there for a quick compillation using some Excel programming.
Hi Beau
You need to define user defined output intervals, in my example the .res file contains all values for all meaures in all requested output intervals for both pass1 and pass2.
Succes!
Erik
Erik,
I was hopeful that using more time steps I would get the output I was looking for as you have said. I have tried this in the past, but gave it another shot this morning. It seems that I only get the first and last time step for each solution pass.
Here is my run definition with the added time steps like you mentioned. I am using a simplifed model to run these trials and here is my .res file with only the first and last time step results for each pass.
Not sure why you can see each time step in your .res file, yet I cannot. My analysis is a static analysis, so maybe that has something to do with it. Not sure. I am running M100 CREO2.
Beau
I'm running Creo 2.0 M010 (not M100)
I get huge amounts of data in my .res file.
I run the lots though, plastic, LDA and contact, and a load with a 20step function (would that make any difference?)
The summary file shows "calculating disp and stress results" for all those steps
Strange.....
Erik
Erik, have you tried to import the .res file into excel and get a quick count on the number of entries in that file? Just to make sure you are getting every measure for every time step.
For instance, my simple model has 65 measures (Interface2_maxTang_traction is the last) from above post. I have a total of 258 entries.
Solution pass 1 : time step 0 = 64, time step last (6) = 64
Solution pass 2: time step 0 = 64, time step last (6) = 64
Plus 2 entries for the Solution pass values
If you are getting all the measures and time steps and you have 20 time steps and ~200 measures then you should have roughly 8000 entries total. If your .res file is like mine then you will only have about 800 entries if you have 200 measures.
I tried looking into the config file, but nothing jumped out at me to try and change.
I also forgot to say that my summary file looks similar to yours with calculations at each time step.
Really
I forgot how to attach a file, so I include the full .res, that'll teach em
Measure Convergence Plotting File
Analysis: krimp_mom18554_fric_plast2
43 columns
1 rows
col quantity
1 p-loop pass number
2 total_cost 242362
3 total_mass 242368
4 com_x 242578
5 com_y 242584
6 com_z 242590
7 contact_area 242632
8 contact_max_pres 242638
9 inertia_xx 242596
10 inertia_xy 242602
11 inertia_xz 242608
12 inertia_yy 242614
13 inertia_yz 242620
14 inertia_zz 242626
15 max_beam_bending 242380
16 max_beam_tensile 242386
17 max_beam_torsion 242650
18 max_beam_total 242392
19 max_disp_mag 242398
20 max_disp_x 242404
21 max_disp_y 242410
22 max_disp_z 242416
23 max_prin_mag 242446
24 max_rot_mag 242422
25 max_rot_x 242428
26 max_rot_y 242434
27 max_rot_z 242440
28 max_stress_prin 242566
29 max_stress_vm 242452
30 max_stress_xx 242458
31 max_stress_xy 242476
32 max_stress_xz 242482
33 max_stress_yy 242464
34 max_stress_yz 242488
35 max_stress_zz 242470
36 min_stress_prin 242572
37 strain_energy 242494
38 Hetmoment_teruggerekend 479596
39 Interface1_any_slippage 3660150
40 Interface1_area 3660162
41 Interface1_complete_slippage 3660156
42 Interface1_force 3660168
43 Interface1_max_tang_traction 3660144
MEASURE_DATA
1 0.000000e+000 4.950859e+001 3.770305e+002 3.609554e+002 -9.001962e+001
1.478486e+004 1.346144e+005 8.335167e+006 -6.338355e+006 1.685669e+006
8.133266e+006 1.515231e+006 1.558605e+007 0.000000e+000 0.000000e+000
0.000000e+000 0.000000e+000 5.113624e-002 4.963491e-002 1.560648e-002
-3.390333e-002 2.624913e+005 5.487603e-005 -4.138810e-006 -3.391902e-006
5.461450e-005 2.624913e+005 2.250726e+005 2.493417e+005 -6.467952e+004
1.286512e+005 6.545666e+004 -6.005481e+004 1.978611e+005 -1.379991e+005
2.723248e+007 7.879814e+007 5.148630e+004 1.478486e+004 -2.455790e+004
1.311850e+006 5.937859e+004
0.000000e+000 4.950859e+001 3.770305e+002 3.770305e+002 3.770305e+002
1.478486e+004 1.346144e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 2.624913e+005 2.624913e+005
2.624913e+005 2.624913e+005 5.113624e-002 5.113624e-002 5.113624e-002
5.113624e-002 2.624913e+005 5.487603e-005 5.487603e-005 5.487603e-005
5.487603e-005 2.624913e+005 2.624913e+005 2.624913e+005 2.624913e+005
2.624913e+005 2.624913e+005 2.624913e+005 2.624913e+005 2.624913e+005
2.723248e+007 7.879814e+007 5.148630e+004 1.478486e+004 2.455790e+004
1.478189e+004 1.338278e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 5.190227e-002 5.098419e-002 1.681199e-002
-3.388676e-002 2.635932e+005 7.568591e-005 -4.708105e-006 -4.559390e-006
7.540161e-005 2.635932e+005 2.250724e+005 2.501302e+005 -6.593170e+004
1.286421e+005 6.625204e+004 -6.060250e+004 1.984915e+005 -1.373906e+005
2.723494e+007 2.255337e+008 5.210734e+004 1.478189e+004 -2.458958e+004
4.495107e+004 5.983987e+004
1.478189e+004 1.338278e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 2.635932e+005 2.635932e+005
2.635932e+005 2.635932e+005 5.190227e-002 5.190227e-002 5.190227e-002
5.190227e-002 2.635932e+005 7.568591e-005 7.568591e-005 7.568591e-005
7.568591e-005 2.635932e+005 2.635932e+005 2.635932e+005 2.635932e+005
2.635932e+005 2.635932e+005 2.635932e+005 2.635932e+005 2.635932e+005
2.723494e+007 2.255337e+008 5.210734e+004 1.478189e+004 2.458958e+004
1.474789e+004 1.327371e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 6.113766e-002 5.947387e-002 2.457051e-002
-3.378415e-002 2.683524e+005 2.067988e-004 -8.283441e-006 -1.190943e-005
2.062893e-004 2.683524e+005 2.249028e+005 2.553867e+005 -7.357547e+004
1.285891e+005 7.084540e+004 -6.420189e+004 2.022132e+005 -1.385965e+005
2.736426e+007 1.149028e+009 5.638935e+004 1.474789e+004 -2.491906e+004
8.570500e+006 6.322864e+004
1.474789e+004 1.327371e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 2.683524e+005 2.683524e+005
2.683524e+005 2.683524e+005 6.113766e-002 6.113766e-002 6.113766e-002
6.113766e-002 2.683524e+005 2.067988e-004 2.067988e-004 2.067988e-004
2.067988e-004 2.683524e+005 2.683524e+005 2.683524e+005 2.683524e+005
2.683524e+005 2.683524e+005 2.683524e+005 2.683524e+005 2.683524e+005
2.736426e+007 1.149028e+009 5.638935e+004 1.474789e+004 2.491906e+004
1.463725e+004 1.830024e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 8.171869e-002 7.807989e-002 4.177251e-002
3.419351e-002 2.785041e+005 4.950160e-004 -1.617718e-005 -2.806779e-005
4.939548e-004 2.785041e+005 2.248752e+005 2.651148e+005 -8.535868e+004
1.284613e+005 8.417288e+004 -7.239109e+004 2.082399e+005 -1.836389e+005
2.833851e+007 3.172737e+009 6.885357e+004 1.463725e+004 -3.006396e+004
2.723587e+007 7.680435e+004
1.463725e+004 1.830024e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 2.785041e+005 2.785041e+005
2.785041e+005 2.785041e+005 8.171869e-002 8.171869e-002 8.171869e-002
8.171869e-002 2.785041e+005 4.950160e-004 4.950160e-004 4.950160e-004
4.950160e-004 2.785041e+005 2.785041e+005 2.785041e+005 2.785041e+005
2.785041e+005 2.785041e+005 2.785041e+005 2.785041e+005 2.785041e+005
2.833851e+007 3.172737e+009 6.885357e+004 1.463725e+004 3.006396e+004
1.430403e+004 2.633624e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 1.106635e-001 1.036823e-001 6.603016e-002
3.576015e-002 2.911771e+005 9.171775e-004 -2.444286e-005 -5.133627e-005
9.154134e-004 2.911771e+005 2.255694e+005 2.754127e+005 -8.724457e+004
1.281348e+005 -1.211100e+005 -8.138820e+004 2.186092e+005 -2.750277e+005
3.212475e+007 5.983564e+009 8.829063e+004 1.430403e+004 -2.870666e+004
5.280184e+007 9.026448e+004
1.430403e+004 2.633624e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 2.911771e+005 2.911771e+005
2.911771e+005 2.911771e+005 1.106635e-001 1.106635e-001 1.106635e-001
1.106635e-001 2.911771e+005 9.171775e-004 9.171775e-004 9.171775e-004
9.171775e-004 2.911771e+005 2.911771e+005 2.911771e+005 2.911771e+005
2.911771e+005 2.911771e+005 2.911771e+005 2.911771e+005 2.911771e+005
3.212475e+007 5.983564e+009 8.829063e+004 1.430403e+004 2.870666e+004
1.372901e+004 3.103591e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 1.464523e-001 1.303392e-001 9.176712e-002
3.629193e-002 -3.391999e+005 1.384274e-003 -5.144953e-005 -7.923832e-005
1.381046e-003 3.046513e+005 2.294493e+005 2.920349e+005 -9.560955e+004
-1.287648e+005 -1.807838e+005 -7.309730e+004 2.003561e+005 -3.391999e+005
3.997866e+007 8.789734e+009 8.505996e+004 1.372901e+004 -3.051764e+004
7.938818e+007 9.918449e+004
1.372901e+004 3.103591e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 3.391999e+005 3.391999e+005
3.391999e+005 3.391999e+005 1.464523e-001 1.464523e-001 1.464523e-001
1.464523e-001 3.391999e+005 1.384274e-003 1.384274e-003 1.384274e-003
1.384274e-003 3.391999e+005 3.391999e+005 3.391999e+005 3.391999e+005
3.391999e+005 3.391999e+005 3.391999e+005 3.391999e+005 3.391999e+005
3.997866e+007 8.789734e+009 8.505996e+004 1.372901e+004 3.051764e+004
1.340221e+004 3.166330e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 1.759922e-001 1.538612e-001 1.137163e-001
3.666906e-002 -3.653947e+005 1.799387e-003 -4.120002e-005 -9.989734e-005
1.796140e-003 3.111268e+005 2.307400e+005 3.049816e+005 -1.035574e+005
1.278006e+005 -2.166974e+005 -8.374017e+004 1.982329e+005 -3.653947e+005
4.142194e+007 1.083485e+010 8.742216e+004 1.340221e+004 -3.070185e+004
9.727249e+007 1.136656e+005
1.340221e+004 3.166330e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 3.653947e+005 3.653947e+005
3.653947e+005 3.653947e+005 1.759922e-001 1.759922e-001 1.759922e-001
1.759922e-001 3.653947e+005 1.799387e-003 1.799387e-003 1.799387e-003
1.799387e-003 3.653947e+005 3.653947e+005 3.653947e+005 3.653947e+005
3.653947e+005 3.653947e+005 3.653947e+005 3.653947e+005 3.653947e+005
4.142194e+007 1.083485e+010 8.742216e+004 1.340221e+004 3.070185e+004
1.318521e+004 3.196044e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 1.900874e-001 1.679000e-001 1.243192e-001
3.688914e-002 -3.744332e+005 2.007948e-003 -4.144600e-005 -1.109268e-004
2.004454e-003 3.156096e+005 2.318235e+005 -3.198492e+005 -1.080255e+005
1.281440e+005 -2.339351e+005 -8.019885e+004 1.947673e+005 -3.744332e+005
4.427291e+007 1.176821e+010 9.274965e+004 1.318521e+004 -3.139229e+004
1.059082e+008 1.204569e+005
1.318521e+004 3.196044e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 3.744332e+005 3.744332e+005
3.744332e+005 3.744332e+005 1.900874e-001 1.900874e-001 1.900874e-001
1.900874e-001 3.744332e+005 2.007948e-003 2.007948e-003 2.007948e-003
2.007948e-003 3.744332e+005 3.744332e+005 3.744332e+005 3.744332e+005
3.744332e+005 3.744332e+005 3.744332e+005 3.744332e+005 3.744332e+005
4.427291e+007 1.176821e+010 9.274965e+004 1.318521e+004 3.139229e+004
1.314348e+004 3.203905e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 1.923987e-001 1.702046e-001 1.260644e-001
3.686448e-002 -3.760315e+005 2.042261e-003 -4.152366e-005 -1.127458e-004
2.038723e-003 3.164167e+005 2.320317e+005 -3.244804e+005 -1.087149e+005
1.282060e+005 -2.365737e+005 -7.960249e+004 1.942826e+005 -3.760315e+005
4.476092e+007 1.191666e+010 9.384257e+004 1.314348e+004 -3.148140e+004
1.070158e+008 1.214349e+005
1.314348e+004 3.203905e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 3.760315e+005 3.760315e+005
3.760315e+005 3.760315e+005 1.923987e-001 1.923987e-001 1.923987e-001
1.923987e-001 3.760315e+005 2.042261e-003 2.042261e-003 2.042261e-003
2.042261e-003 3.760315e+005 3.760315e+005 3.760315e+005 3.760315e+005
3.760315e+005 3.760315e+005 3.760315e+005 3.760315e+005 3.760315e+005
4.476092e+007 1.191666e+010 9.384257e+004 1.314348e+004 3.148140e+004
1.314348e+004 3.203710e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 1.924014e-001 1.702075e-001 1.260670e-001
3.686499e-002 -3.760107e+005 2.042334e-003 -4.152391e-005 -1.127497e-004
2.038797e-003 3.164165e+005 2.320321e+005 -3.244879e+005 -1.087162e+005
1.282065e+005 -2.365636e+005 -7.958361e+004 1.942756e+005 -3.760107e+005
4.476124e+007 1.191669e+010 9.384741e+004 1.314348e+004 -3.148008e+004
1.070582e+008 1.214385e+005
1.314348e+004 3.203710e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 3.760107e+005 3.760107e+005
3.760107e+005 3.760107e+005 1.924014e-001 1.924014e-001 1.924014e-001
1.924014e-001 3.760107e+005 2.042334e-003 2.042334e-003 2.042334e-003
2.042334e-003 3.760107e+005 3.760107e+005 3.760107e+005 3.760107e+005
3.760107e+005 3.760107e+005 3.760107e+005 3.760107e+005 3.760107e+005
4.476124e+007 1.191669e+010 9.384741e+004 1.314348e+004 3.148008e+004
0.000000e+000 0.000000e+000 1.924018e-001 1.702079e-001 1.260673e-001
3.686450e-002 -3.760105e+005 2.042343e-003 -4.152683e-005 -1.127505e-004
2.038805e-003 3.164165e+005 2.320321e+005 -3.244877e+005 -1.087162e+005
1.282065e+005 -2.365632e+005 -7.958354e+004 1.942755e+005 -3.760105e+005
4.476127e+007 1.191669e+010 9.384749e+004 1.314348e+004 -3.148055e+004
1.070682e+008 1.214386e+005
1.558605e+007 1.558605e+007 1.558605e+007 3.760105e+005 3.760105e+005
3.760105e+005 3.760105e+005 1.924018e-001 1.924018e-001 1.924018e-001
1.924018e-001 3.760105e+005 2.042343e-003 2.042343e-003 2.042343e-003
2.042343e-003 3.760105e+005 3.760105e+005 3.760105e+005 3.760105e+005
3.760105e+005 3.760105e+005 3.760105e+005 3.760105e+005 3.760105e+005
4.476127e+007 1.191669e+010 9.384749e+004 1.314348e+004 3.148055e+004
1.316563e+004 3.155342e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 1.903146e-001 1.681196e-001 1.245327e-001
3.682299e-002 -3.700337e+005 2.012813e-003 -4.164722e-005 -1.112077e-004
2.009307e-003 3.155466e+005 2.301335e+005 -3.208369e+005 -1.065358e+005
1.281836e+005 -2.339333e+005 -7.998143e+004 1.946801e+005 -3.700337e+005
4.433221e+007 1.176824e+010 9.280041e+004 1.316563e+004 -3.149808e+004
1.053263e+008 1.198080e+005
1.316563e+004 3.155342e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 3.700337e+005 3.700337e+005
3.700337e+005 3.700337e+005 1.903146e-001 1.903146e-001 1.903146e-001
1.903146e-001 3.700337e+005 2.012813e-003 2.012813e-003 2.012813e-003
2.012813e-003 3.700337e+005 3.700337e+005 3.700337e+005 3.700337e+005
3.700337e+005 3.700337e+005 3.700337e+005 3.700337e+005 3.700337e+005
4.433221e+007 1.176824e+010 9.280041e+004 1.316563e+004 3.149808e+004
1.335304e+004 2.851179e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 1.772825e-001 1.550789e-001 1.149451e-001
3.653706e-002 -3.350312e+005 1.827568e-003 -4.183178e-005 -1.014602e-004
1.824270e-003 3.102119e+005 2.272451e+005 3.060636e+005 -1.046404e+005
1.279415e+005 -2.169169e+005 -8.313180e+004 1.979114e+005 -3.350312e+005
4.178668e+007 1.083409e+010 8.653130e+004 1.335304e+004 -3.111003e+004
9.736088e+007 1.068433e+005
1.335304e+004 2.851179e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 3.350312e+005 3.350312e+005
3.350312e+005 3.350312e+005 1.772825e-001 1.772825e-001 1.772825e-001
1.772825e-001 3.350312e+005 1.827568e-003 1.827568e-003 1.827568e-003
1.827568e-003 3.350312e+005 3.350312e+005 3.350312e+005 3.350312e+005
3.350312e+005 3.350312e+005 3.350312e+005 3.350312e+005 3.350312e+005
4.178668e+007 1.083409e+010 8.653130e+004 1.335304e+004 3.111003e+004
1.340238e+004 2.187595e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 1.510415e-001 1.333038e-001 9.574238e-002
-3.553704e-002 3.216252e+005 1.466371e-003 -5.081607e-005 -8.349359e-005
1.463109e-003 3.216252e+005 2.259832e+005 2.993044e+005 9.684992e+004
1.280306e+005 -1.791908e+005 -7.694356e+004 1.954340e+005 -2.660083e+005
4.033774e+007 8.791900e+009 8.182734e+004 1.340238e+004 -3.022229e+004
7.630657e+007 9.360071e+004
1.340238e+004 2.187595e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 3.216252e+005 3.216252e+005
3.216252e+005 3.216252e+005 1.510415e-001 1.510415e-001 1.510415e-001
1.510415e-001 3.216252e+005 1.466371e-003 1.466371e-003 1.466371e-003
1.466371e-003 3.216252e+005 3.216252e+005 3.216252e+005 3.216252e+005
3.216252e+005 3.216252e+005 3.216252e+005 3.216252e+005 3.216252e+005
4.033774e+007 8.791900e+009 8.182734e+004 1.340238e+004 3.022229e+004
1.422050e+004 1.627528e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 1.132820e-001 1.052468e-001 6.835685e-002
3.509323e-002 3.049892e+005 9.557764e-004 -2.951852e-005 -5.398602e-005
9.537938e-004 3.049892e+005 2.258645e+005 2.596548e+005 -1.084721e+005
1.278256e+005 1.661424e+005 -8.276163e+004 2.089360e+005 -1.771730e+005
3.271315e+007 5.973745e+009 7.061455e+004 1.422050e+004 -2.854580e+004
4.950854e+007 8.911758e+004
1.422050e+004 1.627528e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 3.049892e+005 3.049892e+005
3.049892e+005 3.049892e+005 1.132820e-001 1.132820e-001 1.132820e-001
1.132820e-001 3.049892e+005 9.557764e-004 9.557764e-004 9.557764e-004
9.557764e-004 3.049892e+005 3.049892e+005 3.049892e+005 3.049892e+005
3.049892e+005 3.049892e+005 3.049892e+005 3.049892e+005 3.049892e+005
3.271315e+007 5.973745e+009 7.061455e+004 1.422050e+004 2.854580e+004
1.457869e+004 1.517114e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 8.336493e-002 7.939560e-002 4.422501e-002
-3.445870e-002 2.285386e+005 5.372665e-004 -1.970418e-005 -3.072223e-005
5.360253e-004 2.285386e+005 2.283482e+005 2.231139e+005 -9.286542e+004
1.281947e+005 1.145935e+005 -7.594550e+004 2.083827e+005 -1.591574e+005
2.933524e+007 3.165737e+009 7.527346e+004 1.457869e+004 -2.546002e+004
2.745803e+007 8.354853e+004
1.457869e+004 1.517114e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 2.285386e+005 2.285386e+005
2.285386e+005 2.285386e+005 8.336493e-002 8.336493e-002 8.336493e-002
8.336493e-002 2.285386e+005 5.372665e-004 5.372665e-004 5.372665e-004
5.372665e-004 2.285386e+005 2.285386e+005 2.285386e+005 2.285386e+005
2.285386e+005 2.285386e+005 2.285386e+005 2.285386e+005 2.285386e+005
2.933524e+007 3.165737e+009 7.527346e+004 1.457869e+004 2.546002e+004
1.454702e+004 1.585264e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 6.278286e-002 6.082700e-002 2.708069e-002
-3.469942e-002 2.149173e+005 2.495360e-004 -1.183000e-005 -1.459100e-005
2.488280e-004 2.149173e+005 2.258882e+005 2.005803e+005 9.987019e+004
1.282514e+005 9.395328e+004 -6.854149e+004 2.033452e+005 -1.588756e+005
2.836699e+007 1.141652e+009 7.261907e+004 1.454702e+004 -2.358106e+004
8.622957e+006 1.055305e+005
1.454702e+004 1.585264e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 2.258882e+005 2.258882e+005
2.258882e+005 2.258882e+005 6.278286e-002 6.278286e-002 6.278286e-002
6.278286e-002 2.258882e+005 2.495360e-004 2.495360e-004 2.495360e-004
2.495360e-004 2.258882e+005 2.258882e+005 2.258882e+005 2.258882e+005
2.258882e+005 2.258882e+005 2.258882e+005 2.258882e+005 2.258882e+005
2.836699e+007 1.141652e+009 7.261907e+004 1.454702e+004 2.358106e+004
1.445612e+004 1.646147e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 5.350817e-002 5.234019e-002 1.925901e-002
-3.481638e-002 2.110943e+005 1.176980e-004 -8.370644e-006 -7.214948e-006
1.171781e-004 2.110943e+005 2.266523e+005 1.931464e+005 1.065255e+005
1.283402e+005 8.103628e+004 -6.456536e+004 1.996178e+005 -1.668267e+005
2.823297e+007 2.180742e+008 5.525032e+004 1.445612e+004 -2.339984e+004
2.387761e+005 1.107888e+005
1.445612e+004 1.646147e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 2.266523e+005 2.266523e+005
2.266523e+005 2.266523e+005 5.350817e-002 5.350817e-002 5.350817e-002
5.350817e-002 2.266523e+005 1.176980e-004 1.176980e-004 1.176980e-004
1.176980e-004 2.266523e+005 2.266523e+005 2.266523e+005 2.266523e+005
2.266523e+005 2.266523e+005 2.266523e+005 2.266523e+005 2.266523e+005
2.823297e+007 2.180742e+008 5.525032e+004 1.445612e+004 2.339984e+004
1.445612e+004 1.646146e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 2.180745e+008 5.525031e+004 1.445612e+004 -2.339984e+004
1.445612e+004 1.646146e+005 1.558605e+007 1.558605e+007 1.558605e+007
0.000000e+000 2.180745e+008 5.525031e+004 1.445612e+004 2.339984e+004
2 0.000000e+000 4.950859e+001 3.770305e+002 3.609554e+002 -9.001962e+001
1.473381e+004 1.284571e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 5.081773e-002 4.896360e-002 1.629970e-002
-3.436343e-002 2.556283e+005 6.839168e-005 -4.977228e-006 -4.205872e-006
6.808054e-005 2.556283e+005 2.250200e+005 2.443971e+005 -6.673902e+004
1.292479e+005 8.900537e+004 -6.458527e+004 2.283992e+005 -1.458003e+005
2.695580e+007 9.669284e+007 6.051683e+004 1.473381e+004 -2.537683e+004
1.630995e+006 6.461339e+004
1.473381e+004 1.284571e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 2.556283e+005 2.556283e+005
2.556283e+005 2.556283e+005 5.081773e-002 5.081773e-002 5.081773e-002
5.081773e-002 2.556283e+005 6.839168e-005 6.839168e-005 6.839168e-005
6.839168e-005 2.556283e+005 2.556283e+005 2.556283e+005 2.556283e+005
2.556283e+005 2.556283e+005 2.556283e+005 2.556283e+005 2.556283e+005
2.695580e+007 9.669284e+007 6.051683e+004 1.473381e+004 2.537683e+004
1.472925e+004 1.286928e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 5.078824e-002 4.945279e-002 1.759144e-002
-3.441758e-002 2.564038e+005 8.985103e-005 -5.472448e-006 -5.398793e-006
8.952158e-005 2.564038e+005 2.249300e+005 2.451816e+005 -6.669424e+004
1.292446e+005 9.023618e+004 -6.365510e+004 2.278719e+005 -1.457668e+005
2.695824e+007 2.431363e+008 6.173981e+004 1.472925e+004 -2.530547e+004
2.318142e+005 6.474501e+004
1.472925e+004 1.286928e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 2.564038e+005 2.564038e+005
2.564038e+005 2.564038e+005 5.078824e-002 5.078824e-002 5.078824e-002
5.078824e-002 2.564038e+005 8.985103e-005 8.985103e-005 8.985103e-005
8.985103e-005 2.564038e+005 2.564038e+005 2.564038e+005 2.564038e+005
2.564038e+005 2.564038e+005 2.564038e+005 2.564038e+005 2.564038e+005
2.695824e+007 2.431363e+008 6.173981e+004 1.472925e+004 2.530547e+004
1.468555e+004 1.303323e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 6.060685e-002 5.835993e-002 2.590970e-002
-3.476295e-002 2.614230e+005 2.252366e-004 -8.579219e-006 -1.291797e-005
2.247021e-004 2.614230e+005 2.248845e+005 2.502361e+005 -7.445776e+004
1.292236e+005 9.787189e+004 -6.373862e+004 2.273699e+005 -1.455691e+005
2.709277e+007 1.164699e+009 6.044799e+004 1.468555e+004 -2.489366e+004
8.323025e+006 6.640300e+004
1.468555e+004 1.303323e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 2.614230e+005 2.614230e+005
2.614230e+005 2.614230e+005 6.060685e-002 6.060685e-002 6.060685e-002
6.060685e-002 2.614230e+005 2.252366e-004 2.252366e-004 2.252366e-004
2.252366e-004 2.614230e+005 2.614230e+005 2.614230e+005 2.614230e+005
2.614230e+005 2.614230e+005 2.614230e+005 2.614230e+005 2.614230e+005
2.709277e+007 1.164699e+009 6.044799e+004 1.468555e+004 2.489366e+004
1.451826e+004 2.044938e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 8.248562e-002 7.793687e-002 4.446498e-002
-3.557765e-002 2.724186e+005 5.272973e-004 -1.552035e-005 -2.969141e-005
5.262319e-004 2.724186e+005 2.255277e+005 2.609668e+005 7.198353e+004
1.292029e+005 1.147905e+005 -6.089268e+004 2.038060e+005 -2.078172e+005
2.811244e+007 3.184477e+009 6.562437e+004 1.451826e+004 -3.104764e+004
2.708435e+007 7.074155e+004
1.451826e+004 2.044938e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 2.724186e+005 2.724186e+005
2.724186e+005 2.724186e+005 8.248562e-002 8.248562e-002 8.248562e-002
8.248562e-002 2.724186e+005 5.272973e-004 5.272973e-004 5.272973e-004
5.272973e-004 2.724186e+005 2.724186e+005 2.724186e+005 2.724186e+005
2.724186e+005 2.724186e+005 2.724186e+005 2.724186e+005 2.724186e+005
2.811244e+007 3.184477e+009 6.562437e+004 1.451826e+004 3.104764e+004
1.417733e+004 3.016727e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 1.151281e-001 1.055735e-001 7.112037e-002
-3.710871e-002 -3.331331e+005 9.745382e-004 -2.570996e-005 -5.451521e-005
9.726725e-004 2.849193e+005 2.315225e+005 -2.818750e+005 -9.505531e+004
1.290863e+005 -1.579172e+005 5.556028e+004 1.974806e+005 -3.331331e+005
3.125491e+007 5.985878e+009 8.741633e+004 1.417733e+004 -2.891328e+004
5.711914e+007 9.492049e+004
1.417733e+004 3.016727e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 3.331331e+005 3.331331e+005
3.331331e+005 3.331331e+005 1.151281e-001 1.151281e-001 1.151281e-001
1.151281e-001 3.331331e+005 9.745382e-004 9.745382e-004 9.745382e-004
9.745382e-004 3.331331e+005 3.331331e+005 3.331331e+005 3.331331e+005
3.331331e+005 3.331331e+005 3.331331e+005 3.331331e+005 3.331331e+005
3.125491e+007 5.985878e+009 8.741633e+004 1.417733e+004 2.891328e+004
1.375852e+004 3.794291e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 1.552047e-001 1.349610e-001 1.007329e-001
-3.927637e-002 -4.387882e+005 1.503552e-003 -3.492458e-005 -8.353372e-005
1.500824e-003 2.946874e+005 2.421482e+005 -3.767530e+005 -1.225232e+005
1.290689e+005 -2.683161e+005 7.103832e+004 -2.256954e+005 -4.387882e+005
3.674508e+007 8.796609e+009 1.181615e+005 1.375852e+004 -3.086121e+004
8.540405e+007 1.239667e+005
1.375852e+004 3.794291e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 4.387882e+005 4.387882e+005
4.387882e+005 4.387882e+005 1.552047e-001 1.552047e-001 1.552047e-001
1.552047e-001 4.387882e+005 1.503552e-003 1.503552e-003 1.503552e-003
1.503552e-003 4.387882e+005 4.387882e+005 4.387882e+005 4.387882e+005
4.387882e+005 4.387882e+005 4.387882e+005 4.387882e+005 4.387882e+005
3.674508e+007 8.796609e+009 1.181615e+005 1.375852e+004 3.086121e+004
1.334117e+004 4.293607e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 1.888854e-001 1.647236e-001 1.262552e-001
-4.155648e-002 -5.136883e+005 1.982619e-003 -3.333584e-005 -1.086061e-004
1.979362e-003 3.006103e+005 2.534150e+005 -4.352276e+005 -1.368354e+005
1.291285e+005 -3.430798e+005 7.715215e+004 -2.969479e+005 -5.136883e+005
4.344862e+007 1.083381e+010 1.315116e+005 1.334117e+004 -3.456187e+004
9.104973e+007 1.411762e+005
1.334117e+004 4.293607e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 5.136883e+005 5.136883e+005
5.136883e+005 5.136883e+005 1.888854e-001 1.888854e-001 1.888854e-001
1.888854e-001 5.136883e+005 1.982619e-003 1.982619e-003 1.982619e-003
1.982619e-003 5.136883e+005 5.136883e+005 5.136883e+005 5.136883e+005
5.136883e+005 5.136883e+005 5.136883e+005 5.136883e+005 5.136883e+005
4.344862e+007 1.083381e+010 1.315116e+005 1.334117e+004 3.456187e+004
1.313686e+004 4.547554e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 2.055291e-001 1.810629e-001 1.392033e-001
-4.262514e-002 -5.497957e+005 2.227162e-003 -4.266312e-005 -1.226355e-004
2.223374e-003 3.005668e+005 2.576681e+005 -4.628000e+005 -1.409636e+005
1.306012e+005 -3.882527e+005 8.181053e+004 -3.340412e+005 -5.497957e+005
4.622813e+007 1.176961e+010 1.308385e+005 1.313686e+004 -3.643786e+004
1.046768e+008 1.469885e+005
1.313686e+004 4.547554e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 5.497957e+005 5.497957e+005
5.497957e+005 5.497957e+005 2.055291e-001 2.055291e-001 2.055291e-001
2.055291e-001 5.497957e+005 2.227162e-003 2.227162e-003 2.227162e-003
2.227162e-003 5.497957e+005 5.497957e+005 5.497957e+005 5.497957e+005
5.497957e+005 5.497957e+005 5.497957e+005 5.497957e+005 5.497957e+005
4.622813e+007 1.176961e+010 1.308385e+005 1.313686e+004 3.643786e+004
1.309684e+004 4.592011e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 2.085066e-001 1.839959e-001 1.415219e-001
-4.276041e-002 -5.556623e+005 2.271722e-003 -4.392926e-005 -1.251393e-004
2.267848e-003 3.005324e+005 2.586687e+005 -4.665758e+005 -1.417459e+005
1.303645e+005 -3.969021e+005 8.242007e+004 -3.401859e+005 -5.556623e+005
4.686919e+007 1.191822e+010 1.292640e+005 1.309684e+004 -3.671727e+004
1.070996e+008 1.478783e+005
1.309684e+004 4.592011e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 5.556623e+005 5.556623e+005
5.556623e+005 5.556623e+005 2.085066e-001 2.085066e-001 2.085066e-001
2.085066e-001 5.556623e+005 2.271722e-003 2.271722e-003 2.271722e-003
2.271722e-003 5.556623e+005 5.556623e+005 5.556623e+005 5.556623e+005
5.556623e+005 5.556623e+005 5.556623e+005 5.556623e+005 5.556623e+005
4.686919e+007 1.191822e+010 1.292640e+005 1.309684e+004 3.671727e+004
1.309801e+004 4.591910e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 2.084438e-001 1.839422e-001 1.414745e-001
-4.281063e-002 -5.558134e+005 2.270773e-003 -4.340827e-005 -1.250259e-004
2.266913e-003 3.005887e+005 2.580427e+005 -4.671098e+005 -1.413887e+005
1.303526e+005 -3.969043e+005 8.244631e+004 -3.397778e+005 -5.558134e+005
4.684150e+007 1.191855e+010 1.296299e+005 1.309801e+004 -3.681620e+004
1.070999e+008 1.478965e+005
1.309801e+004 4.591910e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 5.558134e+005 5.558134e+005
5.558134e+005 5.558134e+005 2.084438e-001 2.084438e-001 2.084438e-001
2.084438e-001 5.558134e+005 2.270773e-003 2.270773e-003 2.270773e-003
2.270773e-003 5.558134e+005 5.558134e+005 5.558134e+005 5.558134e+005
5.558134e+005 5.558134e+005 5.558134e+005 5.558134e+005 5.558134e+005
4.684150e+007 1.191855e+010 1.296299e+005 1.309801e+004 3.681620e+004
1.309801e+004 4.592036e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 2.084423e-001 1.839409e-001 1.414735e-001
-4.280707e-002 -5.558247e+005 2.270757e-003 -4.338732e-005 -1.250226e-004
2.266898e-003 3.005971e+005 2.580432e+005 -4.671242e+005 -1.413953e+005
1.303502e+005 -3.969145e+005 8.244631e+004 -3.397854e+005 -5.558247e+005
4.684138e+007 1.191855e+010 1.296989e+005 1.309801e+004 -3.681600e+004
1.071680e+008 1.478964e+005
1.309801e+004 4.592036e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 5.558247e+005 5.558247e+005
5.558247e+005 5.558247e+005 2.084423e-001 2.084423e-001 2.084423e-001
2.084423e-001 5.558247e+005 2.270757e-003 2.270757e-003 2.270757e-003
2.270757e-003 5.558247e+005 5.558247e+005 5.558247e+005 5.558247e+005
5.558247e+005 5.558247e+005 5.558247e+005 5.558247e+005 5.558247e+005
4.684138e+007 1.191855e+010 1.296989e+005 1.309801e+004 3.681600e+004
1.312474e+004 4.500237e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 2.060443e-001 1.815580e-001 1.396620e-001
-4.266369e-002 -5.463129e+005 2.236441e-003 -4.292240e-005 -1.231563e-004
2.232635e-003 2.989347e+005 2.579266e+005 -4.584961e+005 -1.365701e+005
1.286778e+005 -3.941021e+005 8.231079e+004 -3.353345e+005 -5.463129e+005
4.636197e+007 1.176975e+010 1.294266e+005 1.312474e+004 -3.652726e+004
1.021222e+008 1.481384e+005
1.312474e+004 4.500237e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 5.463129e+005 5.463129e+005
5.463129e+005 5.463129e+005 2.060443e-001 2.060443e-001 2.060443e-001
2.060443e-001 5.463129e+005 2.236441e-003 2.236441e-003 2.236441e-003
2.236441e-003 5.463129e+005 5.463129e+005 5.463129e+005 5.463129e+005
5.463129e+005 5.463129e+005 5.463129e+005 5.463129e+005 5.463129e+005
4.636197e+007 1.176975e+010 1.294266e+005 1.312474e+004 3.652726e+004
1.327069e+004 3.799102e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 1.875338e-001 1.637081e-001 1.252531e-001
-3.977219e-002 -4.688119e+005 1.924073e-003 -5.354859e-005 -1.079691e-004
1.920295e-003 3.043641e+005 2.395546e+005 -3.882721e+005 -1.163104e+005
1.316353e+005 -3.840121e+005 1.163540e+005 -3.127414e+005 -4.688119e+005
5.374821e+007 1.079752e+010 1.338736e+005 1.327069e+004 -3.467907e+004
1.121903e+008 1.339641e+005
1.327069e+004 3.799102e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 4.688119e+005 4.688119e+005
4.688119e+005 4.688119e+005 1.875338e-001 1.875338e-001 1.875338e-001
1.875338e-001 4.688119e+005 1.924073e-003 1.924073e-003 1.924073e-003
1.924073e-003 4.688119e+005 4.688119e+005 4.688119e+005 4.688119e+005
4.688119e+005 4.688119e+005 4.688119e+005 4.688119e+005 4.688119e+005
5.374821e+007 1.079752e+010 1.338736e+005 1.327069e+004 3.467907e+004
1.364982e+004 2.530514e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 1.603490e-001 1.380984e-001 1.053718e-001
-4.059395e-002 3.874709e+005 1.597164e-003 -3.917110e-005 -8.898564e-005
1.594202e-003 3.874709e+005 2.379943e+005 3.308718e+005 -1.033340e+005
1.272117e+005 -3.332922e+005 1.105322e+005 -2.668231e+005 -3.684203e+005
4.278605e+007 8.791564e+009 1.475377e+005 1.364982e+004 -2.901571e+004
7.581250e+007 1.475377e+005
1.364982e+004 2.530514e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 3.874709e+005 3.874709e+005
3.874709e+005 3.874709e+005 1.603490e-001 1.603490e-001 1.603490e-001
1.603490e-001 3.874709e+005 1.597164e-003 1.597164e-003 1.597164e-003
1.597164e-003 3.874709e+005 3.874709e+005 3.874709e+005 3.874709e+005
3.874709e+005 3.874709e+005 3.874709e+005 3.874709e+005 3.874709e+005
4.278605e+007 8.791564e+009 1.475377e+005 1.364982e+004 2.901571e+004
1.401856e+004 1.740219e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 1.161829e-001 1.065420e-001 7.160632e-002
-4.044350e-002 -2.855978e+005 9.859274e-004 -3.383463e-005 -5.609762e-005
9.837485e-004 2.334441e+005 2.382515e+005 2.285373e+005 -1.017424e+005
1.280663e+005 -2.805033e+005 7.155342e+004 -2.045455e+005 -2.855978e+005
3.742730e+007 6.021772e+009 1.234741e+005 1.401856e+004 -2.999138e+004
4.871107e+007 1.306221e+005
1.401856e+004 1.740219e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 2.855978e+005 2.855978e+005
2.855978e+005 2.855978e+005 1.161829e-001 1.161829e-001 1.161829e-001
1.161829e-001 2.855978e+005 9.859274e-004 9.859274e-004 9.859274e-004
9.859274e-004 2.855978e+005 2.855978e+005 2.855978e+005 2.855978e+005
2.855978e+005 2.855978e+005 2.855978e+005 2.855978e+005 2.855978e+005
3.742730e+007 6.021772e+009 1.234741e+005 1.401856e+004 2.999138e+004
1.414590e+004 1.605954e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 8.641844e-002 8.123094e-002 4.909305e-002
-3.656636e-002 2.226683e+005 5.971678e-004 -1.863608e-005 -3.375370e-005
5.959218e-004 2.226683e+005 2.423376e+005 2.152506e+005 -9.717328e+004
1.293059e+005 1.520096e+005 -6.991889e+004 1.805329e+005 -1.925433e+005
3.078247e+007 3.166724e+009 1.269737e+005 1.414590e+004 -2.798986e+004
2.576916e+007 1.300361e+005
1.414590e+004 1.605954e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 2.423376e+005 2.423376e+005
2.423376e+005 2.423376e+005 8.641844e-002 8.641844e-002 8.641844e-002
8.641844e-002 2.423376e+005 5.971678e-004 5.971678e-004 5.971678e-004
5.971678e-004 2.423376e+005 2.423376e+005 2.423376e+005 2.423376e+005
2.423376e+005 2.423376e+005 2.423376e+005 2.423376e+005 2.423376e+005
3.078247e+007 3.166724e+009 1.269737e+005 1.414590e+004 2.798986e+004
1.432797e+004 1.570543e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 6.431626e-002 6.148340e-002 3.053011e-002
-3.614437e-002 -2.245160e+005 2.966401e-004 -1.323272e-005 -1.724566e-005
2.958426e-004 2.238789e+005 2.431253e+005 2.178140e+005 -1.000298e+005
1.291958e+005 -1.566904e+005 -7.715723e+004 1.908824e+005 -2.245160e+005
2.919365e+007 1.150293e+009 1.194052e+005 1.432797e+004 -2.792174e+004
9.397869e+006 1.281566e+005
1.432797e+004 1.570543e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 2.431253e+005 2.431253e+005
2.431253e+005 2.431253e+005 6.431626e-002 6.431626e-002 6.431626e-002
6.431626e-002 2.431253e+005 2.966401e-004 2.966401e-004 2.966401e-004
2.966401e-004 2.431253e+005 2.431253e+005 2.431253e+005 2.431253e+005
2.431253e+005 2.431253e+005 2.431253e+005 2.431253e+005 2.431253e+005
2.919365e+007 1.150293e+009 1.194052e+005 1.432797e+004 2.792174e+004
1.432168e+004 1.560606e+005 8.335167e+006 -6.338355e+006 1.685669e+006
0.000000e+000 0.000000e+000 5.436320e-002 5.250659e-002 2.200813e-002
-3.578572e-002 -2.308583e+005 1.584550e-004 -1.017567e-005 -9.583436e-006
1.578373e-004 2.262342e+005 2.435780e+005 2.190668e+005 -1.002920e+005
1.285162e+005 1.337856e+005 6.680250e+004 1.893341e+005 -2.308583e+005
2.905348e+007 2.286947e+008 1.170078e+005 1.432168e+004 -2.498362e+004
1.033624e+005 1.325104e+005
1.432168e+004 1.560606e+005 1.558605e+007 1.558605e+007 1.558605e+007
1.558605e+007 1.558605e+007 1.558605e+007 2.435780e+005 2.435780e+005
2.435780e+005 2.435780e+005 5.436320e-002 5.436320e-002 5.436320e-002
5.436320e-002 2.435780e+005 1.584550e-004 1.584550e-004 1.584550e-004
1.584550e-004 2.435780e+005 2.435780e+005 2.435780e+005 2.435780e+005
2.435780e+005 2.435780e+005 2.435780e+005 2.435780e+005 2.435780e+005
2.905348e+007 2.286947e+008 1.170078e+005 1.432168e+004 2.498362e+004
1.432168e+004 1.560607e+005 8.335167e+006 -6.338355e+006 1.685669e+006
-3.578572e-002 -2.308584e+005 1.584550e-004 -1.017567e-005 -9.583436e-006
1.578373e-004 2.262316e+005 2.435780e+005 2.190667e+005 -1.002920e+005
1.285161e+005 1.337855e+005 6.680209e+004 1.893349e+005 -2.308584e+005
0.000000e+000 2.286951e+008 1.170078e+005 1.432168e+004 -2.498355e+004
1.432168e+004 1.560607e+005 1.558605e+007 1.558605e+007 1.558605e+007
0.000000e+000 2.286951e+008 1.170078e+005 1.432168e+004 2.498355e+004
Erik
Yep every time step. I am jealous. I wonder why I can't get my output like that?
I've just made my email adres open for registered users
You can send me a version of your model, I should be able to run it in M010.
let's see what happens.....
Erik
ehaenen
(To:ehaenen)
Hi Beau
Did you receive my mail with answers?
Erik
Erik,
I did receive your email, but haven't had a chance to open up the model yet. I was pushed into another project at work. I will circle back to it when I get free. Thank you for your time, help, and info on bolts.
At the end of the day, the model can't have shell elements, only solids.
Hi Erik,
Thank you for helping Beau - would it be possible to see the solution? I am sure the rest of the community would be interested.
Best,
Toby
ehaenen
(To:Tmetcalf)
Hi Toby
Regards
Erik
Thank you Erik
