Computer processors
mjohn36886
Computer processors
Gurus, can you help explain how this works.
Is dual core or quad core better for Pro-E?
Is dual core or quad core better for Mechanica?
I have 6 GB of ram on Windows XP x64, do I have to configure the 3 gig
switch I hear people talking about for Pro or Mechanica to utilize?
If so, how do you configure the switch?
Thanks in advance for all your help and insight.
Mike Johnson
Senior CAD Designer
Carlisle Industrial Brake & Friction
812-334-8797
8 REPLIES 8
Mike,
Pro/E can't take advantage of multiple processors (except maybe in assy retrieval?), so dual or quad (or even single) doesn't matter. Processor speed is more important to Pro/E than number of cores. Given the choice between more cores and more speed, take more speed.
Mechanica, on the other hand, I believe can use multiple cores, I believe. I'm not a mechanica user, so I'm not certain.
If you're running 64 bit windows you don't need the 3 gig switch, in fact it probably isn't even available. I think you may need to be running 64 bit Pro/E to take advantage of the extra memory.
Doug Schaefer
LinkedIn
BenLoosli
(To:mjohn36886)
While Pro/E does not take advantage of multiple CPUs/Cores, the system as a whole can. You can run Pro/E on one core while the OS, Office and other apps use the other core(s).
The 64bit version of Pro/E is required to take advantage of the extra memory.
Thank you,
Ben H. Loosli
USEC, INC.
Does the x64 version of ProE WF5 M050 use the 64 bit imbedded browser also?
Would multi-core processors still help? Even though Pro/E might not be able to use them directly, would they allow other things running on the machine to be shuffled off to another processor, thereby effectively giving Pro/E more resources?
Thanks.
Frank H. Strieffler,
Project Specialist Staff
Mechanical Hardware & Test
Lockheed Martin Engineering
Cherry Hill, NJ
Mike,
I am not a Computer Processor expert by any means.
As for the question about RAM. The 3 gig switch for Windows XP is only
related to the 32bit version of the OS. A 32bit OS can't see anything
larger than 3 GB of RAM. If you are running a 64bit OS, you don't need to
do anything in order for all the RAM to be visible and usable by the OS.
This however does not mean that a software application is optimized for
using that RAM or Multiple Processor Cores.
I believe that Wildfire 4 supported multiple processors for threading an
assembly but not sure how much support Pro/E has for multi-core setups
across the board. I am running Wildfire 5 on Windows 7 Professional
64-bit. We have 6GB or Ram on some systems and 12GB on others. We are
running Quad Core's but I could not tell you if Wildfire 5 is taking
advantage of them.
Pro/E supports multi-core, but I think it's only for specific operations.
Damián Castillo
CAD & Administration Manager
Engineering Department
Hensley Industries
I don't think you can find processors without multi-cores anymore. I can
only hope Pro/E or CREO Elements/Pro will support them across all
functions. I seriously don't think PTC will be using many resources on
CREO elements/pro anymore, so the real question will be if CREO 1.0 will
support multi-cores across all functions. It would be nice.
I do agree that your entire system will benefit from multi-core even if
Pro/E does not. If you run other apps outside of CREO elements/pro, you
will benefit from the additional processors and RAM.
Damián Castillo
Hensley Industries
I also think that with i7 chips, there is some internal "shenanigan" that allow things to run faster with multi-cores... Sorry if I got too technical... Nyuk! Nyuk! Nyuk! 😉
Thanks...
Paul Korenkiewicz
FEV, Inc.
4554 Glenmeade
Auburn Hills, MI., 48326
As I understand the 'shenanigans' with the i7 & i5 (but not the i3, I believe) is that it will allow 'overclocking' for short bursts. In other words, the processor runs at X speed most of the time, but it will go Y% faster for short bursts.
Doug Schaefer
LinkedIn
