Config setting drawing_name_sameas_model_name not working
kdirth
Has anyone tried the config setting drawing_name_sameas_model_name?  The documentation I found for it says "yes" will auto select the check box for Use drawing model file name.
I found it today and set it to yes.  When I tried making a new drawing for a part, the checkbox on the New window was not checked for me.  Using 7.7.5.0
kdirth
(To:kdirth)
I removed the PTC folder, no Creo subfolder in it as mentioned in CS35023, from C:\Users\Kdirth\AppData\Local and restarted Creo.  It is now working.
3 REPLIES 3
TomU
(To:kdirth)
Yes, it's working for me in 7.0.5.0 and later.
See if this article helps:  https://www.ptc.com/en/support/article/CS350233
kdirth
(To:TomU)
I closed Creo and deleted the Creo folder at C:\Users\Kdirth\AppData\Roaming\PTC, as suggested in the article, then restarted Creo.  The box remains unchecked when I create a drawing for a new part.
kdirth
(To:kdirth)
