Has anyone tried the config setting drawing_name_sameas_model_name? The documentation I found for it says "yes" will auto select the check box for Use drawing model file name.
I found it today and set it to yes. When I tried making a new drawing for a part, the checkbox on the New window was not checked for me. Using 7.7.5.0
I removed the PTC folder, no Creo subfolder in it as mentioned in CS35023, from C:\Users\Kdirth\AppData\Local and restarted Creo. It is now working.
Yes, it's working for me in 7.0.5.0 and later.
See if this article helps: https://www.ptc.com/en/support/article/CS350233
I closed Creo and deleted the Creo folder at C:\Users\Kdirth\AppData\Roaming\PTC, as suggested in the article, then restarted Creo. The box remains unchecked when I create a drawing for a new part.
