Configuring the color schemes of the Fluent UI in Creo Elements/Direct Drafting
bparody
Hi all,
I just find annoying changing Creo Elements/Direct Drafting to Cocreate background. When I run the program it always starts with Creo colors. To avoid resetting the color scheme for each session, anyone knows a persistent method?
Thanks in advance
2 REPLIES 2
lfortner
(To:bparody)
To avoid resetting the color scheme for each session, add:
CREO_ELEM_COLOR OFF
CREO_VIEWPORT_COLOR OFF
to the user's customization (ex: customize.m).
Thanks for your help. I have just changed the customize.m file and it worked! Thank you so much.
