How can we convert CGM file to Step file
Well, without trying it myself, I'd guess you could read the CGM file into Creo then save as STEP. Hopefully the type of data in the CGM file is amenable to outputting it as a STEP file.I don't have a CGM file so I can't do any testing.
According to the Help Center, CGM can be imported with Creo https://support.ptc.com/help/creo/creo_pma/r11.0/usascii/index.html#page/data_exchange/interface/To_Import_a_CGM_File.html
Yeah, I figured that if a direct CGM -> STEP converter wasn't something someone had, they could use Creo as the intermediary to translate the data. The only problem I foresee is that translation from format to format can sometimes result in inaccuracies or other weird results. The "wrong" half of an arc being written in the translated file, non-tangencies, etc.
Former CAD data translation engineer here ☝️😁 and i get the feel too.
conversion can feel like throwing spaghettis on a wall and see what sticks indeed.
In the end, if it fails file a case and we will assist promptly.
Hello @DD_13455715,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
