Converting NX into Creo and extracting to .prt file
Stephen_DeLeon
Right now we have a customer who is giving an NX file project, so we imported the model into creo and it was opened as an assembly and then I used IDD to clean it up. Now I need to extract one specific part as a (.prt file) since we will put it in CREO tool deisgn extension (which requires .prt file). I have tried (1) Copy/publish geometry however the part does not appear when I open it. I have tried (Shrinkwrap). however this option leaves holes in the surfaces. Any help will be appreciated.
Thank you.
4 REPLIES 4
Hi
The assistance that you need requires access to the model.
I recommend either you share the NX model here or file a case for more security and confidentiality.
Alright, noted on this. I will make a case.
Thank you.
Hi @Stephen_DeLeon
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina
PTC Community Moderator
PTC
Not sure if this work for you, but there is a hidden config.pro option called
intf3d_in_as_part YES
