Converting STL to .prt
shopperton
I have a human head in STL format and am attempting to Creo some head-wear. Is there any way of converting an STL into a Creo part file that can be used to drop curves onto? I have tried using the Shrinkwrap method but the results are too inaccurate.
Many thanks,
Sam
4 REPLIES 4
Or alternatively, does anyone know of a head model available for use in Creo Parametric?
This is the PTC Live Global community. You should probably repost in the Creo community.
ryankelley
(To:mmuth)
Moved this discussion into our Creo community.
This is a multi-post of the same question. Is there a way to wipe out duplicates?
