Converting STL to .prt
  • March 27, 2015
  • 2 replies
  • 5702 views
I have a human head in STL format and am attempting to Creo some head-wear. Is there any way of converting an STL into a Creo part file that can be used to drop curves onto? I have tried using the Shrinkwrap method but the results are too inaccurate.
Many thanks,
Sam
Or alternatively, does anyone know of a head model available for use in Creo Parametric?
This is the PTC Live Global community. You should probably repost in the Creo community.
Moved this discussion into our Creo community.
This is a multi-post of the same question. Is there a way to wipe out duplicates?
