Correct way to populate Harness Package in Vehicle Assembly
Yogesh.T
Now this gets tricky for me as I move ahead with Cabling.
I have:
= The whole vehicle assembly,
          -Sub assembly
                  -Main Parts
                           -Screws /nuts / bolts
Then comes HARNESS at the end.
Now I have 1098 Harnesses in this BEAST.
What is the best way to organize my HARNESSES?? See attached image.
What should be my approach?
I have to get it right from get go or will waste 10x ::::))))
If you guys can make me sleep well for this weekend, nothing like it 🙂
THANKS IN ADVANCE FOR YOUR TIPS!
Hi @Yogesh.T
Thank you for your question.
Best regards,
Catalina
PTC Community Moderator
PTC
Yogesh.T
(To:Catalina)
Image attached for more clarity. How should be the assembly structure of if wire, if cable....
