Corrupted PDF's
ptc-593619
Corrupted PDF's
One of the things that appealed to us with WF5.0 was the ease of
producing PDF's via the "Publish" tab. However, I am experiencing some
problems for which I have no answer. The PDF is produced with a nice
appearance but for some reason, a couple of views are corrupted. In
these views, data is all shown correctly but the actual view image is at
half scale. The drawing is 1:1 and the majority of the views take the
drawing scale. (The exception is an end view at 2:1 scale). Can anyone
enlighten me as to how to correct this anomaly? We're using M060 BTW.
Unfortunately, I cannot show a picture as it is for a client but if you
need further info, let me know.
Richard A. Black
Lead Design Engineer
Eaton Corporation
440 Murray Hill Road
Southern Pines
NC 28387 USA
tel: 910 695 2905
fax: 910 695 2901
www.eaton.com
5 REPLIES 5
Related issue with using WF5.0's PDF publisher (i believe 4.0 may have had this issue as well:
  • Part modeled in MM
  • DWG of part shows inches primary with 3 decimal pnts and mm secondary with 2 decimal pnts
  • When applying a tolerance to a DRIVEN dimension on the drawing, for example5.000 +/-.012[127 +/-,30], the PDF will completely turn the secondary mm dimensions into erronenous numbersdecimals.
  • We have found insuch cases if you edit the dimension text and add a space in the text after the callout the PDF willbe ok.
  • This happens with the TRIUMVARITE font.
unacceptable bug in my opinion.
Of the items listed by Pete even to the font, we have them all - so I
guess it's back to the cutePDF printer for now.
Richard A. Black
Eaton Corporation
Southern Pines
NC 28387 USA
Richard,
I also use the pdf function in WF5. I use...
File, Save a Copy, PDF.
I'm on build M040 and I know there is a problem with the way Pro/E creates the pdf. I can view them all day long on MY MACHINE ONLY without any problems. If I send them to anyone else, they can't open the file. Not only that, but the pdf files are very large in size. I have been told that build M080 corrected this problem, along with another problem of the "change part color" balls showing up very slowly in Pro/E.
I get around the pdf problem by first opening up my new pdf file in Acrobat and then print the pdf file to a freebee pdf printer driver (doPDF) that I downloaded from the internet. The resultant pdf is about 1/4 - 1/5 as big as the one directly from Pro/E and it will open on ANY computer - without incident. Kludge workaround, but it DOES work.
Bob Schwerdlin
Design Engineer,
Dukane Corp.
2900 Dukane Dr.
St. Charles, IL 60174
630-797-4974 direct
Just noticed this in the info line - (why couldn't this be at the bottom
per normal?)
"[1]PDF shaded image was required to be scaled down during export, a
lower dpi setting may avoid this".
Changed from 600dpi to 400dpi - SUCCESS!!!!
Richard A. Black
Eaton Corporation
Southern Pines
NC 28387 USA
I had the same problem in WF5 with PDFs created on my own machine viewing just fine, but when they were sent to others they could not open them. I was able to solve the problem by changing the type of PDF being output. When doing a SAVE A COPY – PDF, in the PDF EXPORT SETTINGS dialogue box, under the CONTENT tab, there is a COMPATABILITY box which allows you to select between PDF and PDF/A1 formats. When I switch to using the PDF/A1 format, other people that I send the PDF files to can open them just fine. Based upon your specific requirements this may or may not solve your problem. Here’s a link to the Wiki on the PDF/A - type formats:
