Create a PDF
dgrobe
Create a PDF
im wondering how to publish to a PDF, so it pops up the PDF, before i have to save it.  in intralink, the pdf would show up on the screen, then do a file save as, and name it.  this one wants me to name it before i create it.  i dont really want to do that.  i would rather have the pdf show up, then look it over before i save it.
thanks
Try this mapkey "caf".  Created in Creo2.  Just add to your local config.pro
If you need this for WF, let me know.  there is a little difference.
I do a couple things before I create the pdf.  I first turn the datums off (d-), then I zoom-reset (zr) the window.
I also supplied my .dop file for Adobe. Place that in your work or "start in" directory.
If it doesn't work, use yours (adjust code below - "bad1pdf" with yours). Adjust it as you see fit.
mapkey d- @MAPKEY_NAMESwitch off all datum display options;\
mapkey(continued) @MAPKEY_LABEL>Datum display off;\
mapkey(continued) ~ Activate `main_dlg_cur` \
mapkey(continued) `igToolbar_AncestorIGT_IGT_GRP_inh396938342.proe_win|.mcs29658718_mp|select_\
mapkey(continued) all_check` 0;
mapkey zr @MAPKEY_NAMEZoom reset;@MAPKEY_LABEL>Zoom reset;\
~ Command `ProCmdViewRefit`;
mapkey caf @MAPKEY_NAMEMakes a .pdf file and stores\nit in your work \
mapkey(continued) directory;@MAPKEY_LABEL>Create Adobe File;%d-;%zr;\
~ Command `ProCmdModelMkPdf';\
~ Select `intf_profile` `opt_profile`1  `bad1pdf`;\
~ Activate `intf_profile` `OkPshBtn`;
Daniel,
Does the information in Ron's reply answer your query? You may mark that reply as correct answer fro the post.
