Create a representative mass dummy
I sometimes create parts that are supposed to simulate the actual part but cost a fraction to produce. Ie the machined part should have the correct mass, center of gravity and ideally same, or similar responses as the purchased component. It will then be used for harsh mechanical testing, instead of potentially destroying an expensive component.
This is a tedious trial and error process but is there a way of having Creo doing at least some of the work for me? Such as if I design a representative shape and I know that it should have a specific mass, I would extrude a hole (or several holes) to match the correct mass. Can I make Creo vary for example the depth of such a hole until the correct mass is met?
Next will be to have Creo change the position of such a hole to meet the correct center of gravity.
