Create menu drop-down annotation feature
MuriloSilva
I created a parameter with restriction, when I open the panel parameters it is displayed with a list of options, but when I create a annotation feature and link with this parameter, I can't edit this annotation with menu drop-down. I only can edit by text.
Someone know some method that I can create a  menu drop-down parameter in screen of creo?
My assembly have many relations and parameters that control this model.
The parameters have many options, and answer only by text is difficult.
2 REPLIES 2
I don't think it's possible to get the dropdown on that value edit panel, at least in Creo Parametric 2.0.
Will have to see if this is different in Creo Parametric 4.0.
Thank you James.
Provisionally, I created the parameter restriction within the annotation.
I associated this parameter with the information that will be visible on the screen and created a mapkey so that the user can click on the annotation and open the parameters screen annotation quickly.
This way the user can answer using the combo-box and will only be displayed the parameter he wants to answer.
