Hello, is there any way how to create surface from surface of solid part?
I have an assembly with sheetmetal parts and need to create a part in this assembly from some surfaces of the sheetmetal parts.
I can create surface with modeling tools, extrude,... but is is too complicated. I would like to just select
the surface of the part and copy (create) this as a new surface. something like create surface by copying existing surface.
This part of surfaces I want to export to ansys workbench.
in creo 3
Thanks for help
michal
Michael,
You may try creating a new part in assembly, activate that part and copy the surfaces from part by part in assembly.
Michael,
Do You mean copy and paste? This really works....
This didn't cross my mind..
Thanks.
Yes, It was copy and paste.
