can you save a dxf file from ptc creo elements direct?
aschleifer
Is there any way to export or save a dxf file from creo elements direct?
Hi Arthur,
yes give it, but there is a lot of work and requires some additional programs.
The result is also not that great, arcs and circles are changed into vectors.
Have tried it and was not so impressed.
Convert STL to DXF using Open Source tools
Best regards
(Please write info in your Signature) Sysinfo: I use Creo Elements Direct Drafting, Modeling and Express 6-8-9 ( formerly CoCreate- SolidDesigner and Drafting or ME10 )
Hi Arthur,
You can definitely save directly to DXF from the Annotation module, and it should be a regular DXF file.  Just select File->Save and select the type as DXF.  Then specify the name and any other options and click save.
If you're doing a lot of data conversion, we at AI MAXTools have a solution (AI DataMAX) that may help. AI MAX Export2D allows you to save 2D data into multiple formats (any combination of PDF, DXF, DWG, IGES) in a single operation, including the ability to batch convert a whole folder of .drawing files  Similarly, AI MAX Export (for 3D) allows you to export multiple 3D objects into all supported formats in a single operation.
If you'd like to know more, just let me know. I'd be glad to provide any info you need.
Good luck!
andy
Andy Poulsen
AI MAXTools: Dream. Design. Done. It's That Easy!
Add-in products to make PTC® Creo® Elements/Direct®  and CoCreate® products even faster!
www.ai-maxtools.com
