Oct 3, 2017 11:53 AM UTC
Creating BOM table in Creo Drawing involving sub assemblies components
I have an assembly model that involves 2 sub-assemblies. When I add automatic BOM table the subassemblies appears in the table, while I need to add a BOM table to the assembly drawing covering all components ( main and sub-assembly).  Can anyone have a solution (BOM of all components and not subassembly names)?
Oct 10, 2017 7:57 AM UTC
you can apply filter on your repeat region. Something like
&asm.mbr.type == PART
StephenW
Oct 3, 2017 12:00 PM UTC
Your BOM table is set to be "FLAT". You can change to be "RECURSIVE"
Go to the table tab, repeat region, select attributes, select your table, select recursive then done.
Oct 9, 2017 10:59 PM UTC
Thanks Stephen
I followed that process and now I have all the parts and also assemblies name on the table, how I can remove the assembly items from the BOM table?
Oct 12, 2017 12:37 PM UTC
Hi Martin
it works!
Thank you all
