Creating Composite Datum Curves
jodyjw
Hi Pros,
How do you create a composite datum curve?
I have two "sketch" curves and two datum curves that I want to make into a composite curve. I get that I need to select one of the curves and use edit > copy and edit > paste to create the composite curve. But when I try to do this the copy "dashboard" does not come up. I starts the window like it does when you create a regular datum curve or a sketch curve, depending on which one is selected when I do the copy, paste.
I did this a few months ago when I had some Mechanica training, but I cannot duplicate it today.
I am sure that I'm not holdingmy mouth right.
Jody
2 REPLIES 2
Hi Jody,
Most likely you're not "fully selecting" the curve. Notice that if you click the curve once it turns red. If you pause and click the curve a second time it turns a bold red. Once it's bold, the composite copy dashboard will open. If you only get the "light red" it will take you into a sketch setup.
One of those nice little ProE features....
Let me know if that works!
Good luck,
TROY MASON
Impulse Product Development
2445 Directors Row Ste C
Indianapolis, IN 46241
317.243.2225
www.impulseproductdevelopment.com
www.facebook.com/impulseproductdevelopment
Thanks Troy.
That's what it was. I just found in on the PTC Users group after I posted it here. Who would have thaught to select it again? ProE is sooo user freindly.
Jody
