I have a set of surface features created from Creo's Welding Application that connect different parts in my assembly. I was wondering if it was possible to easily create geometry under the surface region between the surface feature and the part below. Any suggestions would be greatly appreciated.
Easily? Sort of.
As a separate part it can be useful to compare weld volume, weight, etc...although taken with a grain of salt when compared to the real world. From there you can create a weldment "part" by doing a merge so you have one part that represents an entire weldment for post weld/heat-treat machining, etc. if you so choose.
Hope that helps.
