Creating Shell of Assy
agaribay
3-Visitor
How does one create a Shell of an Assembly file?
I have to send this file to a customer, but only want them to
see the outer shell of the Assembly.
I tried creating a STEP File with Shells
[cid:image001.png@01CF5D4B.C55AB420]
Wildfire 4.0
Thank you.
-Art
This message (including any attachments) contains
confidential and/or proprietary information intended
only for the addressee. Any unauthorized disclosure,
copying, distribution or reliance on the contents of this
information is strictly prohibited and may constitute a violation
of law. If you are not the intended recipient, please notify the
sender immediately by responding to this e-mail, and delete the
message from your system. If you have any questions about this
e-mail please notify the sender immediately.
Art,
You will want to do the Save As but change the file type to Shrinkwrap. This will give you a surface model of the assembly. I would try it out with a small assembly to get use to the settings before you try it out on a large assembly.
Ronald B. Grabau
HP PDE-IT
Roseville, CA
916-785-3298
-<">mailto:->
