Creating gtol to a created dimension
TedOtto
3-Newcomer
I recently upgraded to Creo 2.0 and I'm trying to create a simple True Position Gtolonto a created dimension. I could do this in Wildfire5, but in Creo 2.0it will not let me. I pick the axis for the reference and then try to pick my dimension to attach it to and I get this error: "you cannot link a part/assembly gtol to a drawing dimension." Is there a config.pro setting that would control this?
Thanks!
Ted
1 REPLY 1
TedOtto
3-Newcomer
(To:TedOtto)
Thanks to the two attached responses. Changing the config setting took care of it.
Thanks!
Ted Otto
Senior Designer
TEAM Industries
218-828-1987
