Hello all,
Is it possible to create a surface from a file containing XYZ point info that is formatted like this
Contour 1
+0.00015719 -0.00385578 -0.00240279 in +0.00000000
+0.00015722 -0.00485578 -0.00205918 in +0.00000000
+0.00015724 -0.00585579 -0.00172874 in +0.00000000
+0.00015727 -0.00685579 -0.00141855 in +0.00000000
+0.00015729 -0.00785579 -0.00109718 in +0.00000000
+0.00015732 -0.00885580 -0.00080014 in +0.00000000
+0.00015734 -0.00985580 -0.00048563 in +0.00000000
+0.00015737 -0.01085580 -0.00016993 in +0.00000000
+0.00015739 -0.01185580 +0.00013890 in +0.00000000
+0.00015741 -0.01285581 +0.00044022 in +0.00000000
+0.00015744 -0.01385581 +0.00074184 in +0.00000000
+0.00015746 -0.01485581 +0.00107004 in +0.00000000
EOR
There is only one line stating "Contour 1", then a boatload of point data followed by the "EOR".
I can read this into excell and reformat it a bit, but the only point data examples that I have seen are always formatted like this.
Begin section ! 1
Begin curve ! 1
1 5 0 0
2 4.890738003669028 0 -1.039558454088797
3 4.567727288213004 0 -2.033683215379001
4 4.045084971874737 0 -2.938926261462366
5 3.345653031794291 0 -3.715724127386971
Begin curve ! 2
1 -5 0 0
2 -4.890738003669028 0 1.039558454088797
3 -4.567727288213004 0 2.033683215379001
4 -4.045084971874737 0 2.938926261462366
5 -3.345653031794291 0 3.715724127386971
Begin section !2
Begin curve !2
1 3.871856222212 1 0
2 3.787246874142925 1 -0.805004173763359
3 3.537116664447014 1 -1.574825802294658
4 3.132397483545891 1 -2.275819986413063
5 2.590777501703034 1 -2.877349916529299
Begin curve ! 2
1 -3.871856222212 1 0
2 -3.787246874142925 1 0.805004173763359
3 -3.537116664447014 1 1.574825802294658
4 -3.132397483545891 1 2.275819986413063
5 -2.590777501703034 1 2.877349916529299
Begin section ! 3
Begin curve ! 1
1 3.440383137348 2 0
2 3.365202511401989 2 -0.7152958751469302
3 3.142946387674466 2 -1.399329888179515
4 2.783328425275531 2 -2.022206470368865
5 2.302065654800458 2 -2.556702926179849
Begin curve ! 2
1 -3.440383137348 2 0
2 -3.365202511401989 2 0.7152958751469302
3 -3.142946387674466 2 1.399329888179515
031769111886e-016
4 -2.783328425275531 2 2.022206470368865
5 -2.302065654800458 2 2.556702926179849
Begin section ! 4
Begin curve ! 1
1 1.575 3 0
2 1.515453791431831 3 -0.5284872181462467
3 1.339801061268245 3 -1.030473880404201
4 1.056849770861571 3 -1.480788279414492
5 0.6807882794144922 3 -1.856849770861571
Begin curve ! 2
1 -3.175 3 0
2 -3.115453791431831 3 0.5284872181462467
3 -2.939801061268246 3 1.030473880404201
4 -2.656849770861571 3 1.480788279414492
5 -2.280788279414492 3 1.856849770861571
I believe what I have been handed is not a list points on individual curves, but rather a huge cloud defining a surface.
Any help would be greatly appreciated.
Bob Frindt
Sr. Designer
Parker Hannifin Corporation
Parker Aerospace
Gas Turbine Fuel Systems Division
9200 Tyler Boulevard
Mentor, OH 44060 USA
direct (440) 954-8159
cell: (216) 990-8711
fax: (440) 954-8111
I would like to know if it is possible also.
Hi @AT_12529542 ,
Create a facet "surface" by importing the points as a facet.
Apply the Reconstruct operation to the facet surface.
