Creo 1.0 - Creo 2.0 Upgrade License Server?
dgschaefer
We currently have WF4 - Creo 1.0 installed and running and need to get
Creo 2.0 going. Usually, but not always, a new version means an upgrade
to the license server. This doc:
http://www.ptc.com/WCMS/files/138523/en/Creo_2_readmefirst.pdf
Design Central
Columbus, Ohio
LinkedIn
TomU
(To:dgschaefer)
We are currently running FlexNet 10.8. To add support for Creo 2.0, I simply replaced the relevant sections in the existing license.dat file with the new sections from a new license file (with the license service stopped of course). No issues whatsoever.
Tom Uminn
Engineering Systems Analyst
trans-matic Mfg.
616-820-2499
-<">mailto:->
Dmi3U
(To:dgschaefer)
Doug, I guess I read it the same way as your IT guy. So I Started looking for FlexNET 11.+ for Sun Solaris from PTC - there is NONE. PTC TC confirmed that you do not need to upgrade from FlexNET 10.8 - just swap the license file. It worked.
D
Just to chime in with everyone else. No need to upgrade the license server software, just change out the license file. Works for me, no problems.
David Haigh
bgruman
(To:dgschaefer)
I was able to do a simple file swap from WF4 to Creo2.
Opened LMTools, stopped the server, read the new file, started the server,
All OK.
Doesn't get much easier than that.
Good Luck
Bernie
Bernie Gruman
Owner / Designer / Builder
www.GrumanCreations.com
On Mon, Apr 30, 2012 at 2:24 PM, Doug Schaefer <
> wrote:
> We currently have WF4 – Creo 1.0 installed and running and need to get
> Creo 2.0 going. Usually, but not always, a new version means an upgrade to
> the license server. This doc:****
> http://www.ptc.com/WCMS/files/138523/en/Creo_2_readmefirst.pdf****
Simply updating the license file worked for us.
All the best,
Jered
