This widget could not be displayed.
Creo 2.0 - Open a drawing from active part?
dhanley
2-Explorer
Has anybody managed some sort of shortcut/mapkey for this yet? I'm taking about quickly opening a drawing of same name when the model is on screen, the way you can open a model by right clicking in the drawings model tree . .
33 REPLIES 33
@ptc-3260121 wrote:
Hello Martin,
thanks for your very good application. It is very usefull!!!!
We tried on more PC and until a week ago it worked perfectly.
Now only on one PC the shortcut seems to start but it doesn't complete the opening of the drawing. What it can be? On the other PC as said it continues to work perfectly. The "windows updates" are the same and the PC are identic.
Luca
unfortunately I am not able to guess what is going on on one specific PC.
Simply said there must be some difference ...
You can do following steps to reproduce application functionality:
  • press ALT+F on keyboard to open File menu
  • press O on keyboard to open File Open dialog box
  • in File Name field > type model name + .drw (for example cube.drw if cube.prt is displayed in Creo window)
  • click Open button
Martin Hanák
Hello Martin,
please explain me how I can do so that PROE associate the model_name?
The steps you described are simple but I am not able to do it.
Now the file.exe stops to work on all the PC...........
Please explain the trick to find the active current model_name so that we can mak a mapkey.
Thanks a lot
Luca
@ptc-3260121 wrote:
Hello Martin,
Thanks a lot
Luca
I am sorry I do not understand your question.
Martin Hanák
spapik
(To:dhanley)
I have a question for this ? Can I use it with Windchill 10.2 ?
I understand that it work with local or network drives, but we would like to use it on Windchill workspace.
Can we do it ?
Sandor Papik
