We are VERY new to using Simplfied reps and I am wondering when you open a Light Graphics rep and all you see is boxes....how do you actaully show a light graphics view of the assembly???
Do not use Light Grapics, u need to use Envelope parts.
We have some ASM with more then 10000 parts, this is one Envelope-Part.
Can you explain why we shouldn't use LG reps?
You don't know what you are doing with LG Reps.
What i do
Do not assemble the envelope part, but use rep!
This is a good way to handle large models.
That is why I am asking about them.....
I think he meant it more like "you don't know what Creo is doing with LG reps".
As in it is doing something generic that works only for some users but you have little or no control over exactly what it's doing.
His method gives you complete control over the simplified rep.
What exactly are you trying to accomplish by using simplified reps?
We use simp reps for a couple of reasons.
1. large assembly management - reduce the memory usage to open a model
2. to show a sub-set of parts or assemblies on a drawing that may not be clear when done in other ways
3. variation to products - although I don't consider simplified reps as a good way of managing product variations it comes in handy sometimes when you need to show some variation but you don't want to create a family table.
I haven't experimented with light graphics rep so I'm not sure how it works or what it's purpose is.
Simplified representations is a good tool, but how do you calculate mass properties of simplified assembly? If you calculate mass properties in simplified assembly it will be one value, but if you calculate mass properties in master representation it will be other value. In every iteration of mass properties calculation creo will be think that assembly is changing, and it need to be save and check out from workspace.
Stephen, your correct.... you don't know how Creo is making this light grahpics.
Yep had problems with Simplified reps & windchill check-out.
You need to set in config.pro for Windchill
mp_calc_level assembly_only
mass_prop_update_force_change no
save_objects changed
If you solidify the envelope-part (default=surfaces), then the weight is correct.
Or give the envelope the correct weight, in the mass-prop window.
