I liked your idea but didn't want to maintain another config.pro so decided to just do it in the mapkey. I did not change the datum tags but this is what the mapkey looks like that I created in Creo2:
mapkey dtmoff @MAPKEY_NAMETurn off all Datums;@MAPKEY_LABELDtms Off;\
mapkey(continued) ~ Select `main_dlg_cur` `appl_casc`;~ Close `main_dlg_cur` `appl_casc`;\
mapkey(continued) ~ Command `ProCmdRibbonOptionsDlg` ![]()
mapkey(continued) ~ Select `ribbon_options_dialog` `PageSwitcherPageList` 1 `ConfigLayout`;\
mapkey(continued) ~ Activate `ribbon_options_dialog` `ConfigLayout.SearchOpt`;\
mapkey(continued) ~ Input `find` `EnterKeyword` `display_planes`;\
mapkey(continued) ~ Update `find` `EnterKeyword` `display_planes`;\
mapkey(continued) ~ Activate `find` `EnterKeyword`;~ Open `find` `Values`;\
mapkey(continued) ~ Close `find` `Values`;~ Select `find` `Values` 1 `no`;\
mapkey(continued) ~ Activate `find` `Apply`;~ Activate `find` `find`;\
mapkey(continued) ~ Input `find` `EnterKeyword` `display_axes`;\
mapkey(continued) ~ Update `find` `EnterKeyword` `display_axes`;~ Activate `find` `FindNow`;\
mapkey(continued) ~ Open `find` `Values`;~ Close `find` `Values`;\
mapkey(continued) ~ Select `find` `Values` 1 `no`;~ Activate `find` `Apply`;\
mapkey(continued) ~ Activate `find` `find`;~ Input `find` `EnterKeyword` `display_points`;\
mapkey(continued) ~ Update `find` `EnterKeyword` `display_points`;\
mapkey(continued) ~ Input `find` `EnterKeyword` `display_coord_sys`;\
mapkey(continued) ~ Update `find` `EnterKeyword` `display_coord_sys`;\
mapkey(continued) ~ Activate `find` `FindNow`;~ Open `find` `Values`;~ Close `find` `Values`;\
mapkey(continued) ~ Activate `find` `Close`;~ Activate `ribbon_options_dialog` `OkPshBtn`;\
mapkey(continued) ~ FocusIn `UITools Msg Dialog Future` `no`;\
mapkey(continued) ~ Activate `UITools Msg Dialog Future` `no`;~ Command `ProCmdViewRefit`;
note that I could not get the smiley face out of there so replace the smiley face with a semicolon and back slash ";\"
