Wrap Solid Material around complicated surface?
I have a solid piece of mastic which is heated and formed around a sheet metal door. I can convert it to sheetmetal and make bends so it kind of forms around the contour of the door. I think two Spinal Bends will form it around the door surface? Is there a transaction (WARP?, WRAP?) that will completely form the solid around the door surface? Grey is the solid and blue is the copy geom surface. This is a part, not an assembly. Thank you
