Creo 2 - Line Styles of Imported Features
dhickson
Hello, Everyone,
I am an end user and quite often use an iges wire frame in a skeleton model as a guide or trace part. Problem i am having in when i import the IGES wire frame into a skeleton part i cannot do a mass change of the line styles of the wire frame.
I can go into the data doctor and select lines individually and "right-click" - Line Style and change them that way but in WF4 i could drag a window around the entire model and capture all of the entities.
I even tried using the "model tree" for selection and it does not work.
Any feed back would be helpful and appriciated.
Denny
I cannot recall off hand if IDD makes good use of the filter in the lower right corner. Often, changing the filter allows window selections.
