I am currently working on importing drawings created in WildFire 4.0 to Creo 3.0. One issue I am encountering is witness line lengths after regeneration. In WildFire 4.0, the witness lines were clipped and did not move after regeneration. However, in Creo 3.0, the witness lines seem to be moving back to the point determined by the drawing property witness_line_offset. Is there a configuration option or drawing property I can set that will correct this?
Example: WF4.0
Creo 3.0
