Creo 4.0 Framework custom tube profiles
maddog859
3-Newcomer
Hello all, I am currently on a SAE team and we are learning to use the Framework extension. I am wondering if there is any sort of way to create custom tube profiles? We are using various sizes such as 1"x.095", 1"x.065" and 1"x.045" for our chassis. I checked the metric libraries and haven't found anything that size either. Thanks.
1 REPLY 1
Hi @maddog859,
You can achieve this by performing the following actions:
Add your custom beam:
SEL_STRING = Name in the Framework user interface
BUW_SIZE = Parameter value of the model
DM = Diameter
T = Thickness
Hope that helps.
Greetings Sam
Samuel Brantner
B&W Software GmbH
