Creo Direct Modeling Express Help File
jellison
Is the help file available in pdf ? I would like to read it off line, while lounging etc. I don't see a pdf or chm file in any of the directories. This would be a good addtion if not available. At least for the end user..
TIA
John
2 REPLIES 2
KrisR
(To:jellison)
I have spoken to PTC about this previously in regards to the tutorials on Precision Learning and getting a PDF since we did pay for two subscriptions.
Their stance is this: if it's in a PDF format or a format that can be opened without Pro E installed, then they will not provide it. They are concerned about piracy and it ending up in the hands of folks that do not own a Pro E license.
hkramer
(To:KrisR)
not in PDF. You might open the Help center of Creo Elements/Direct Modeling Express and select the chapters you like to run offline and print them. Using the Print button in the upper right corner.
