Creo Elements/Direct 18.0 version history.
ptc-2055240
Creo Elements/Direct 18.0 version history, compare current version to older versions:
http://www.ptc.com/WCMS/files/129209/en/6683_Creo_Elements_Direct_Modeling_Version_History.pdf
7 REPLIES 7
thanks for sharing these cocreate documents....are these docs available to the public, or just to third party partners such as yourself? It is strange that a third party is sharing out such info when really PTC corporate marketing should be pushing this stuff...this is the continuing problem where PTC corporate marketing largely does not understand the cocreate product line?
This file don't find
Thanks for your help, you do gave me a big favor.
regards,
Yellow
This is a big help to understand if we need to upgrade past 15.50G. Still hate that Error 337 in nearly all of our assemblies. If we could have that option back perminately to override it without a timed license, my company would upgrade in a heart beat.
getting Error 337 means that you have a significant issue in your data.
Suppressing the Error with the license protected switch is not a good idea.
When I became aware that users are permanently using the switch to suppress load failures,
it was *me* who managed to make this switch license protected.
As the inventor of Modeling Filing and the SYSID I want to hear from customers having Error 337.
The right approach is to identify the root cause of a load error (either in your data or in the code)
and get that fixed.
If you prefer to silently ignore load errors, open a Support Case and I will provide a "Filing Switch" license
with a very long lifetime.
Max Kublin, WW Technical Leader - Model Manager Support & Inventor of SYSID, DBA Tools, sd_tools
Max,
Our company had given up dealing with PTC in the Error 337 problems going forward in the newer versions. Thus, 15.50G is the last version our company will ever use. This was also a pivotal making choice on not having CoCreate or Creo as the production CAD software going forward after 2008 and going with SolidWorks. We do go back to the 15.50G daily, lift the block on Error 337, rebuild/repair the files and then export to SolidWorks.
