Creo Elements Pro Schools Edition - no welding?
ptc-4982720
I have just downloaded the Creo Elements Pro Schools Edition and I want to do some welding in my model. The thing is that under my applications there is no welding application. It says in the product description that it allows you to do weld. Maybe I just can't find it, or maybe I am doing something wrong.
Can anyone have any suggestions? Do I have to download a separate welding module (extesion) - if yes then from where.
Any help will be greatly appreciated.
In the full version, there is no special setting during the install to make welding work. It is indeed located in the Applications tab. You could contact the VAR or customer support to confirm.
