Hey folks!
Need a bit of help...
So I’ve got this huge assembly in Creo that takes forever to open — like 30-40 mins easily. When I peeked into the task manager, I noticed it’s only using a single CPU core, even though the machines/workstations have quad-core and some even octa-core processors. Is this normal for Creo? Or is there some any setting or config tweak I may be missing that can make it use all cores and speed things up?
Many thanks in advance.
Ciao,
Srikar
Unfortunately, Creo is mostly a single core program.
Here is a collection of articles that discuss techniques for managing large assemblies:
Article - CS133707 - [Knowledge Hub] Creo Parametric - Large Assembly Management
Creo Parametric is in general a single thread application. For loading models there is no way to enable multithreading within Creo AFAIK.
Adding on, starting in Creo 11 there is a new performance reporting tool:
In general these are poor performers:
See if you can eliminate any of those and or use interchange assemblies to swap out complicated assemblies for simpler representations. Attached is a PTC/User presentation that might be helpful.
Hey Mr. @Chris3 & @kdirth ,
Thanks a lot for you support. This issue/question was eating our team`s brains almost since a week. Now it`s clear for all of us!!
Much appreciate your efforts in addressing this.
And of course, a special mention to @Chris3 & who ever created that presentation. It was smooth and pretty easy to understand.
Ciao,
Srikar.
There is a config option for setting the number of cpu's. I'm not sure how much it helps. It defaults to 6, so even if you don't specify it in your config.pro file it should still pull into your session.
cpus_to_use 6
cpus_to_use 6
AFAIK cpus_to_use is related to Simulate app, only.
I spend most of my days in large assemblies and sometimes the wait time if significantly more than the work time, it can be extremely frustrating.
There really is no one option that makes it all work faster but as mentioned, there are lots of tools within creo to improve the situation
Any time we upgrade, I tend to try to evaluate config.pro options again, this is my current list of options (we are currently using Creo 8 to help our users who deal with large assemblies :
I have tried to make notes to help with understanding but over the years, I have forgotten the reason why the option was added. I would suggest you read the documentation for each and thoroughly test each option to make sure it doesn't cause other problems for you or your company or your assemblies.
OPTION |
VALUE |
REASON |
allow_freeze_failed_assy_comp |
yes |
REQUIRED |
atb_auto_check_on_retrieve |
off |
this should be off, it is on by default |
auto_place_max_number |
1 |
this has to do with auto placement of interface components and can slow down assy of hardware with interface enabled |
auto_regen_views |
no |
REQUIRED - you must manually regen sheets/views, otherwise it causes significant delays |
autoplace_single_comp |
no |
Autoplace interface components can significantly slow assy times |
check_interference_of_matches |
no |
it is possible this option can slow assy times when set to yes (default it yes) |
comp_assemble_with_interface |
none |
comp assy is an interface option that may significantly slow assy times |
create_temp_interfaces |
no |
temporary interfaces can significantly impact assy performance |
enable_auto_regen |
no |
enable auto regen Yes (default) has potentially negative large assy effects |
fasthlr |
no |
unknown effects |
interface_quality |
0 |
this option when set to anything other than zero can seriously affect print time. It is really for PLOTTING, where a pen would got over and over the same line. |
open_simplified_rep_by_default |
yes |
recommended so you don't accidentally open the master rep on a large assy |
shade_quality |
3 |
shade quality is EXTREMELY DETRIMENTAL TO LARGE ASSY PERFORMANCE |
smooth_lines |
no |
unknown effects |
Hey there @StephenW,
The comment you mentioned looks precisely detailed. Let me try this and I`ll get back to you on how it worked for me and then possibly we may discuss a bit more in depth !
@SharmaKona-Adro Yes, definitely. Just keep posting on this thread. Anything you find will very likely help me and others also.
I did just notice that in my post, the editor converted Creo "8" to an emoji. But I do have access to Creo+ (creo 12) to test new options too.
@StephenW here are some that we set that it looks like you do not. Also we have a mapkey that loads and unloads these in with a button in the GUI for them.
Setting | Value | Comment |
Display_in_adding_view | Minimal_wireframe | Sets view displace when auto_regen_views is set to no |
Create_drw_sheet_thumbnails | No | Prevents the pop-up preview when hovering over a drawing tab |
Dwg_show_screentip | No | Turns off hyperlink screen tips |
Enable_fsaa | off | Turns off edge smoothing |
Fasthlr | yes | No performance numbers, but PTC managers have said this provides improvement |
Edge_display_quality | Low |
Thanks @Chris3 my testing has begun.
Some of these I already had, likely from our Admin guys but they don't think in terms of large assembly management.
I'm especially intrigued by edge_display_quality because mine was set to VERY_HIGH.
I think fasthlr for me wasn't a performance thing, I think it was odd anomaly things, I just don't remember right off hand.
