Creo Parametric 3.0 - Templates Problem
jescobarlema
Creo Parametric 3.0 Templates don't work/load when trying to create a new part, why?
Thaks in advance for any information.
2 REPLIES 2
if you want to create your own startup part, then:
  • create new empty directory, for example C:\PTC\mytemplates
  • create part representing your template (for example myprt.prt) and save it into C:\PTC\mytemplates directory
  • put following options into config.pro file:
    • start_model_dir   C:\PTC\mytemplates
    • template_solidpart   C:\PTC\mytemplates\myprt.prt
  • start Creo and create new part
MH
Martin Hanák
Hi Jose,
If you are trying to access the default templates, they are installed in the following location, with the Creo 3.0 installation:
<drive_letter>:\<install_folder>\Creo 3.0\<datecode>\Common Files\templates
Please check if this folder is accessible.
Amit
