We are aware of an issue causing intermittent login problems for some users following a recent update. Learn More
Creo Parametric M250 wont launch after premature exit
VMcD
I am using Creo Parametric 2.0 M250, it was working fine for months. Does anyone have any other tricks I didn't try below?
After Creo prematurely exit, parametric.exe no longer launches. This happened before and after a reinstallation. I tried these options
Check AppData
Check C:\ProgramData\PTC
Check ipconfig /all
Article on VPN issues: Creo Won't Launch - PTC Community
Disabled this Network Adapter: NCP Secure Client Virtual NDIS6.20 Adapter
MartinHanak
(To:VMcD)
Check AppData
Check ipconfig /all
try to look for an error in Event Viewer.
Martin Hanák
