Creo Parametric Options - Favorites - SUMMARY
JLG
Once again, ptcuser to the rescue!
The answer is:
You have to export the favorites you've created into your personal config.pro file.  Every favorite you add will place a line item in your config.pro file like these:
content_favorites_page_options system_colors_file
content_favorites_page_options display_plane_tags
So my config.pro needed to have these two lines:
content_favorites_page_options freeze_failed_assy_comp
freeze_failed_assy_comp no
Works like a charm!  Thanks to Mike for his quick answer.
Kind regards,
Janet Grove
ocorten-2
(To:JLG)
Hi Janet,
Nice tip.
One small note:
The options will only be added to the Favorites if the option is also *set* in the config.
Only adding this line:
will not add it to the favorites.
You must also *set* the option (even if your setting it to the default value)
Kind regards,
Olaf Corten
Olaf Corten | CAD/PLM Manager
Besi Netherlands B.V. | Ratio 6| 6921RW Duiven| The Netherlands
T: +31 26 3196215 | M: +31 644548554
- | www.besi.com
To: "-" <->
Date: 17-09-2014 17:18
Subject: [proecad] - RE: Creo Parametric Options - Favorites - SUMMARY
The answer is:
You have to export the favorites you’ve created into your personal config.pro file. Every favorite you add will place a line item in your config.pro file like these:
Kind regards,
Janet Grove
MikeBrattoli
(To:JLG)
Excellent point Olaf!
Mike Brattoli
On Sep 18, 2014, at 10:37 AM, "Olaf Corten" <-<<a style="COLOR:" blue;=" text-decoration:=" underline&quot;=" target="_BLANK" href="mailto:-">>">mailto:->> wrote:
Hi Janet,
Nice tip.
One small note:
Kind regards,
Olaf Corten
<mime-attachment.gif>
Besi Netherlands B.V.  |  Ratio 6  |  6921RW Duiven  |  The Netherlands
-<">mailtoSmiley Surprised->  |  www.besi.com
