Creo Pro 2.0 Silent Install
ptc-4733834
We just got the the CD for Creo Pro 2.0 and i was looking for a silent or unattenede install. there is only one setup file and it seems it does not take any command line parameters or may be i am missing something. we are deploying our softwares throug SCCM. it is possible to build an MSI package but i though may be there is someone that have an answer for my question
regards
well i know what a script is but i thought if you can post one to see what changes you usually use so i can compare.
I usually use InstallSheild Admin Studio to build MSI packages but any repackager will do the job. after running the CreoPro Installer it "admin studio" will scan the system for changes. I just excluded everything that comes outside this path "c:\program files\PTC" and excluded all the registry changes.
i run the MSI package with the /qb from SCCM and then run the Thmbviewer.msi then creoagent.msi then vcredist_x86_VS2010.exe.
8 REPLIES 8
Ahmed,
I have never heard about installing ProE/Creo through SCCM. Normally CAD admins use the following procedure:
1.] install ProE/Creo on 1 PC
2.] zip installation directory into archive file
3.] copy zip-file to another PC
4.] unzip files
5.] run custom script to complete the installation
Silent installation is implemented in Creo 2.0 M020. See attached Word document.
Martin Hanak
Martin Hanák
Hi
i just created an MSI file "repackaging" and it worked. what script are you talking about ?? am running the viewer msi installer and agent afterwards.
Ahmed,
custom script is script (or batch file) created by customer. This script can for example create shortcuts for launching software, set environment variables, and so on... It depends on customer's needs.
Please can you post detailed description of procedure, that you use. I hope this kind of information can help other users.
Martin Hanak
Martin Hanák
Ahmed,
unfortunatelly I can't post a script, because I do not have it (I am not admin in big company).
Thanks for posting information about creating and applying MSI files.
Martin Hanak
Martin Hanák
Hi im having an issue trying to build an msi, it builds fine using scaleable wininstall but when i go to deploy it via GPO it gives me an error saying to validate the msi / package.
anyone any ideas on the best way to deploy PTC Creo student edition on a network?
thanks
Did anyone ever get this working in SCCM??
I'm trying to do the same now.
Robert Bisset
We are deploying with SCCM.  We just have SCCM call our bat file that has this in it.
setup.exe -xml sim.p.xml -xml pma.p.xml -xml optsmdler.p.xml -xml layout.p.xml -xml dma.p.xml -xml creabose.p.xml -xml mathcad.p.xml -xml creothumbnailviewer.xml -xml creoviewexpress.xml -xml mathcadpdsi.xml -xml mkscomponents.xml
This is for Creo 3 but the same worked for Creo 2.  We also install the help the same way.
