Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Hi all,
I can not make BOM (list of electrical component) in Wiring diagram in Creo Schematics. I need on sheet list of all component and their sum (like a mechanical BOM). Is it possible in Creo Schematics create BOM report? If yes, can you tell me how?
Ludek
Hi
Choose Inventory
Assuming you want to display name and then report on something that can report total for example Part number set the inventory column priority
You will then get the total for part number 123 (2) next to each unique entry of name
If you remove name and uncheck inventory column
the you will get the following results - 123 shown once and with a qty of 2
hope that helps
jim
and total no longer exists...........thanks for the "update" Creo Schematics!!!(((((
who actually uses this program anymore!
Creo Schematics is what happens when you are dependent on closed source software and either they (Creo) lays off the schematics developers or they quite.....Thanks again Creo!!!!
It's highly likely the menu picks have changed since this was posted 6 years ago.
I don't use schematics so I don't know the picks. It's likely someone else can help though.
as soons as you choose inventory in the first tab, the <TOTAL> shows up in that second tab. At least in Creo Sch 7.
