Creo Table -Fixed Index reverting ?
dweich
In Creo drawings - Tables with “Fixed Index” – these are for BOM’s where if you delete a component, that line in the BOM gets skipped.  My company is trying to use this, but it is very quirky.  It often reverts back to previous BOM Item numbers.  Is there a best practice doc?  We’re trying to use Region rather than each Record.  I assume someone is using this successfully?
5 REPLIES 5
Radovan_DT
(To:dweich)
Can you please elaborate more. I know that if you delete fixed part from assembly you need to unfix the part which was deleted like this. That way you can "reuse" the table line
dweich
(To:Radovan_DT)
here is my reply from below - My problem is that my company would like- for example, Item 2- if removed, then 2 will be skipped even if bringing in a new component in the future.  I was told this won't happen, unless I manually renumber the table, which I don't want to do.  EAC helped me find this - SPR 4428325.
Hi @dweich,
Anurag
dweich
(To:anursingh)
BenLoosli
(To:dweich)
What I did to preserve the BOM numbering was create a family table of 99 items that have the item set for each one for position 1-99. If you delete item 5, you add to your assembly Deleted Item 5 part, which is an empty part, and then the BOM will show that item as DELETED in the name field and be item 5 in the index. Had to use ITEM 5 instead of just DELETED in the Number field as that would merge the items to a single line.
