Creo Windchill - Can I copy an associated drawing after forgetting to do this when copying a part?
areid
I recently copied over a complex part model to make a different version of it. Unfortunately the associated drawing was not copied over and I did not check before proceeding to modify part. Is there a way of copying the drawing over after or do I have to start the process from scratch? P
Thanks in advance!!
1 REPLY 1
RonSt.Pierre
(To:areid)
put "rename_drawings_with_object both" in your config.pro
You could continue but it would be difficult to describe especially when the above option and redo is available.
