Is it documented somewhere that the newer versions of Creo don't handle the same releases of SolidWorks as version 9.0.12.0? I would imagine newer versions of Creo would be able to accommodate the same or later versions of SolidWorks, but it is most definitely NOT something I can find any sort of documentation about.
Perhaps someone with more knowledge than I will be able to point you to some sort of table or release notes that gives actual info about this topic.
CS134024 documents this in detail for every format and Creo Version.
Swx2025 ist just specified for Creo9.
according to https://support.ptc.com/cs/release-calendar/index.html?productFamilyIdList=2&productIdList=30 page
I hope that also in Creo 10.0, 11.0, 12,0 released in 2026 SolidWorks 2025 file import will be implemented.
Note: It is necessary to monitor CS134024 regularly.
Hello Martin
Thank you for your reply.
I hope this is the case and they just missed to add this as a note to the newer Creo versions.
Yes, I check CS134024 every 3 months.
Have a good Day
Marc
Hi @boemi
Your questioning is fair. In article CS134024, red item highlights recent updates and the Creo 9.0 updates are more recent than that of Creo 12.
The most efficient choice here is to click the portlet Something is wrong in this article.
This will fire a process and notify the authors of the article directly.
PTC contacted me yesterday and provided the same information.
The CS134024 is now up to date.
