Cross-Section View with Z-Clip
AndrewFeisthamm
So here is my problem...I have a view showing a total cross-section and I would like to not show all of the geometry behind the section, only some of it. However, when I try to add a z-clip, the hatch disappears. The strange part is that it still exists, because it highlights when I put my mouse over it and when I select it, but as soon as I unselect it, the hatch goes away. I suppose I could accomplish the same thing by using a combination of component display and edge display, but that gets kind of cumbersome. Any other suggestions???
3 REPLIES 3
double check that your datum plane for the section is going in the correct direction, usally when i have this problem all i do is flip the plane and that fixes it.
Yeah, I already tried that. The section is pointed to the correct direction and the Z-Clip reference is also on the correct side of the section.
try removing the hatching before applying z-clip. ankur
