The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
I have a Top assembly level drawing that someone has asked me for help removing Harness segments.
The problem is only appearing in the xsections. For example a xsection at station 50 facing aft has harness segments
showing from station 25. I should not see anything but what the section is cutting thru and anything behind the section.
View Settings are cable display thick, full section
WF 3.0 Build M150
Hopefully most of you have found something better to do Labor Day
Douglas K. Bowles
Advanced Systems Harn/Des
520-746-2019 Office
520-490-9395 Cell
