Cross Sheet Graphics
jgottfredson
7-Bedrock
Is anyone here familiar with defining a function to inherit the name of the connected? I would like the "label" on my "Cross Sheet Graphic" to inherit the name of the connected along with the sheet number that it exists on. Right now, the default I assume, is "[dg_xref(-,/)] which will give me the name of the sheet and the location set coordinates. I was thinking that a function using "dg_inherit_from_connected" might give me the name of the splice that the fiber is connecting to. I would like my label to read,in example, (SP-2, SH 4). The SP-2 references the splice name the fiber is connected toand the SH 4, the sheet number that the splice exists on. Is anyone here good with derived parameters?
John
0 REPLIES 0
