Ctrl button does not function correctly with Creo express 4.0
DanKilduff
I downloaded the modeling express 4.0. I found that the use of the CTRL + mouse button combinations with view changes does not work as it used to in PE3.0. The wheel button allows the zoom, but no other mouse button works. I use these quite a bit and would like to see them work again. I will stay with PE 3.0 until then.
1 REPLY 1
For a little more info, I have tried with two different devices a wireless mouse and a wired trackball and both do not work. If this needs to be marked as a bug that's fine, if there is a fix in the program I would appreciate a solution to making it run correctly.
Thank you
If someone else can confirm this that would be helpful as well. I am using a netbook with Windows 7 home premium (I know it is a little close to the low end of the requirments but its what I have and works fine for what I am doing).
