Curve Dimension
aminhas
Curve Dimension
5 REPLIES 5
Use Measure tool in Part mode to find curve dimension at specific location.
Martin Hanák
aminhas
(To:aminhas)
yes but i need accurate can you do that?
I suppressed Sketch 1 and Thicken 1 feature.
I created new Sketch 2 - it contains a projection of silhouette edge into RIGHT datum plane
I used Analysis > Geometry Report > Point and clicked several points on Sketch 2 curve.
I realized that Radius value displayed in Point Analysis dialog box is not constant. On one end it is about 4.0, on second one it is 0.4. This means the projection of the edge is not arc.
MH
Martin Hanák
aminhas
(To:aminhas)
Sir,
     where I download PTC Creo3 Parametric PDX ?
please ask your PTC VAR.
MH
Martin Hanák
