Custom Symbol issue
Ketan_Lalcheta
Custom Symbol issue
In BOM table's repeat region of creo drawing
file, I have set relations using user defined parameter (udp). I am trying to
create a custom symbol which takes udp into it. Value of udp is not populated
once I use custom symbol
” has been created.
Regards
Ketan
Put this in your symbol:
\rpt.rel.YOUR_USER_DEFINED_PARAMETER_HERE\
In other words, I would like to add variable text of symbol as user defined parameter of repeat region..
It is required to be set in variable text or simply in the name?
Its not variable text. Its just text that is located in the symbol wherever you want it.
